[Z06] Shift Knob
Old Jan 16, 2007 | 07:57 AM
DonF's Avatar
DonF
Default Shift ****
Hey, how do you remove the pin in the top of the shift **** to replace the ****? I took the shift pattern plate off but can't seem to pry out the slide pin. Any help would be greatly appreciated. Thanks
Old Jan 16, 2007 | 08:26 AM
dragon84's Avatar
dragon84
You have to pry it up and out if I remember correctly. I used a large flat tip screw driver when I did it a few years ago.
Old Jan 16, 2007 | 08:36 AM
DonF's Avatar
DonF
Default Shift ****
Wow! It must take alot of pressure, I tried last night & bent a small screw driver, then went to a bigger one with out any luck. I will try again tonight with a little more force. I didn't want to break something if there was a trick to doing it. Thanks for the help.
Old Jan 16, 2007 | 08:46 AM
C5 Z16's Avatar
C5 Z16
Default ****
The Devil pin is sometimes very difficult to remove. I used a pair of needle nose vise grips to move it from side to side while pulling up. If prying put something over the leather **** so you do not damage it.
Old Jan 16, 2007 | 09:05 AM
wayneinvirginia's Avatar
wayneinvirginia
Cruise-In VIII Veteran
Check out this thread for some suggestions. The pin in question is most often referred to as the DEMON PIN.
http://forums.corvetteforum.com/show...ight=demon+pin
Old Jan 16, 2007 | 10:48 AM
DonF's Avatar
DonF
Thanks Guys I will give it try again! Don
Old Jan 16, 2007 | 11:05 AM
bb609's Avatar
bb609
Grab hold of it with a pair of vise grips...think of it as a tooth. A little wiggle and a big yank and it should be in your hands!
Old Jan 16, 2007 | 11:12 AM
verskel's Avatar
verskel
I used (2) flat tip / common screwdrivers.
There's a small area towards the front of the pin underneath to get leverage under. Use 1 screwdriver for each side and pry simultaneously......it'll seem like you'll screw up the leather on the shift **** before it gives way.
Those keepers can be a real PITA....
Old Jan 16, 2007 | 11:41 AM
TEXHAWK0's Avatar
TEXHAWK0
If you need a new shifter ****, you just have to buy a new car....
Seriously, there are serveral techniques on the forum for removing the key...
I had too much time on my hands, so I made a tool that slips under both ears of the key. Here are pictures so you can see how the key is shaped.
Old Jan 16, 2007 | 12:01 PM
...Mark...'s Avatar
...Mark...
I used a flathead and vice grips.
I was pulling on that **** so hard, when it finally came loose, i almost broke my jaw from my hand coming up and hitting me in the face..
Old Jan 16, 2007 | 12:15 PM
jbauch357's Avatar
jbauch357
get a good grip on the pin with vice grips and then slide a screwdriver bewteen the jaws of the vicegrips. now place a block of wood or any other kind of spacer on the back side, placing the tip of the screwdriver on the block. now just pull up on the handle and it will slide right out.
Warning - If you cause physical harm to yourself, the rear view mirror, or roof during the process you are doing something wrong.
Leverage is your friend - work smarter, not harder!
pirated pic
Old Jan 16, 2007 | 12:24 PM
hotwheels57's Avatar
hotwheels57
texhawko, that's a clever tool! I used VICE GRIPS, a deep 3/8" socket as a leverage point and a long screw driver...it came right out.
Old Jan 16, 2007 | 02:29 PM
DonF's Avatar
DonF
Thanks for the info, I will wear a helmet & face shield, maybe even an a cup to protect more vital areas.
Old Jan 16, 2007 | 02:40 PM
...Mark...'s Avatar
...Mark...
Skip the cup, shouldn't be neccessary. The helmet and face sheild on the other hand may be a good idea..
Old Jan 16, 2007 | 03:33 PM
401K Z06's Avatar
401K Z06
I tried all these without success when I wanted to chop an inch off the shifter. I finally borrowed a Snap-On mini slide hammer kit from a friend, which worked, but I nearly busted the mirror when it let go.
Old Jan 16, 2007 | 03:48 PM
...Mark...'s Avatar
...Mark...
Thanks.. I knew i wasn't the only one out there that almost ****ed themself or their car up removing it..
I feel a little better now..
Old Jan 18, 2007 | 09:55 PM
C5 Z16's Avatar
C5 Z16
Do that! I am ashamed to say when it let go I whacked myself right between the eyes and cut my nose pretty good. Be careful some are harder than others.
Jeff
To Shift Knob
