Any links for wetsanding?
Old Jan 17, 2007 | 11:19 AM
Vital Velocity's Avatar
Vital Velocity
St. Jude Donor '11
Default Any links for wetsanding?
My car has alot of swirl marks in the clear coat that are visible when the sun hits it at the right angle ( it looks bad ) and im looking to get them worked out, im assuming wetsanding the entire car will do this for me?
Anyone have any tips or links to how to wetsand a car properly?
Any help would be appreciated
Paul
Old Jan 17, 2007 | 11:30 AM
LDB C5's Avatar
LDB C5
You might want to search the "Car Care" section under General Corvette.
Old Jan 17, 2007 | 11:36 AM
7898VETTMAN's Avatar
7898VETTMAN
Try A Fill And Glaze Or Swirl Remover.wet Sanding May Be Too Much.i Use This Product From 3m Called Pink Fill And Glaze But It Is Now Obsolete.just My .02.
Old Jan 17, 2007 | 11:43 AM
corvette-pilot's Avatar
corvette-pilot
Well now that doesn't help much does it
Old Jan 17, 2007 | 12:58 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
If you wish to eliminate excessive swirl marks, wetsanding isn't the solution. Wetsanding will remove some and/or eliminate orange peel. That said, to remove swirl marks:
1. Wash the car with dawn dish soap (to eliminate any wax etc.
2. Clay bar the car.
3. Buff the paint with a high speed buffer on low with a soft foam pad. I'd use a white Lake Country pad and 3M swirl remover. see http://www.topoftheline.com/7durvelpad.html
4. Polish the paint with a black pad and Menerza final polish II. see http://www.properautocare.com/menfinpol.html
5. Finish by hand with a glaze and wax of your choice
There are many different approaches, pads, polishes etc. to use, bottom line, you have to go from gradually from aggressive to less aggressive etc. To be safe, keep the speed down but that means it'll take you longer. After each step you take, check the car in direct sunlight. And always use a pad and polish together, label your pads and keep them in their original bags.
Old Jan 17, 2007 | 12:59 PM
chevyvette1's Avatar
chevyvette1
They are right check with the car care section, but here is my 2 cents, get a Porter Cable, some orange, and some white foam pads, a good polish, I only use Menzerna, Intensive polish(usually orange pad) and Final polish(white pad) and have at it, here are a few pics I did for a friend on his 64 vert that was in storage for many years, granted this car took about 10 to 12 hours to complete,it was BAD, but the results were fantastic, the whole car was pretty much like the before pics
BEFORE
AFTER
Old Jan 17, 2007 | 05:24 PM
Freestyler's Avatar
Freestyler
sweeeet
Old Jan 17, 2007 | 09:33 PM
istsme98's Avatar
istsme98
Old Jan 17, 2007 | 09:44 PM
mattcb's Avatar
mattcb
Originally Posted by istsme98
thats amazing
Old Jan 17, 2007 | 09:48 PM
kidd's Avatar
kidd
Now thats a good job.
Old Jan 19, 2007 | 09:48 AM
chevyvette1
Thank you guys
To Any links for wetsanding?
