Drag Radials
Old Jan 18, 2007 | 12:53 PM
N0TDADYS_98's Avatar
N0TDADYS_98
Default Drag Radials
ok... well it's about time to fix my traction issues and start leaving people behind... but i have a problem...
I DD my car rain,snow, and of course shine... so having tires that meet these needs are important.... So i've decided to buy a 2nd pair of rear wheels to mount with Nitto 555R's. So the question is...
17's or 18'..
17's i assume i'd get more bite... but 18's will yeild more rubber contact....
So what do you think? 17's or 18'?
Old Jan 18, 2007 | 01:23 PM
angman5's Avatar
angman5
Best set up I found so far is the MT drag radial 275 40 17 hooks up real good well beyond 400 RWHP. I have tried the Nittos and BFG in 17 and 18" sizes with not as good 60' times.
Old Jan 18, 2007 | 02:41 PM
JROW's Avatar
JROW
if you are only using the pair of wheels and tires for racing then i wouldn't waste the extra money on 18's. the wheels are more expensive as well as the tires. I would say get a pair of nitto or BFG 315's unless your car is heavily modded and you need something more, than MT et streets are the way to go.
I do the same thing with my wheels and tires, it seems though that once i put the radials on, its hard for me to take them back off! I much prefer having traction all the time when im cruising around... anyway thats just my way of looking at things.
hope that helps
Old Jan 18, 2007 | 02:53 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
I assume you will be driving on the Nittos full time in the good weather months? BFG or M/T are no good for this duty. I would go 17s, get a 17x11 grand sport wheel.
Old Jan 19, 2007 | 11:05 AM
N0TDADYS_98
can a 315's fit 17" Y2k?
Old Jan 19, 2007 | 11:29 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I really wish someone would come out with a 19" drag radial, but I don't think it will happen because of the sidewall height.
Old Jan 19, 2007 | 11:34 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
18's...........cause I can fit them over our 13" rotors
To Drag Radials
