Has been a problem for a while now. It shows in the steering wheel at speeds above 70 mph. Have replaced both front wheels and tires. Have had them off and on so much from balancing attempts that I can't wait to replace the banged up lugs when it's all fixed (if ever).
Can anyone suggest an approach to this problem or have seen it.
Signed,
PO'd in Houston.
Constant. Was balanced out by Discount Tire when I got new wheels over a year or two ago. Since I got new tires all around (pardon the pun) just haven't been able to shake it.
I assume you've checked alignment. Wheel play?
Nothing against Discount, but a decent tire shop will find the answer.
Even if it's not the one you want to hear. Try another shop.
Borrowed a friends 99' and placed his front wheels onto mine with the same results. Did not check allignment or for loose shocks; I will ASAP (great suggestions).
Have been to Corvettes of Houston and Discount Tire for balance; got sucky results from both. They both changed the point at which the shaking occurred.
Was so frustrated was thinking bout' starting my own tire shop. Still may.
I've been working with similar vibration problems-start with, road forced balance, checking run out of tire and wheels. Then allignment and shocks, and then the bearings. When you do a road force balance, do all four as it is possible the vibration may be from the rear also?
Additional info is helpful;
Type/brand tire
Wheel/stock or aftermarket
mileage/abuse car has been subjected to-
Oh yeah, Burgie:
Type/brand tire ; Standard Eagle F1's (factory spec)
Wheel/stock or aftermarket (aftermarket Z06/chrome; have replaced both front wheels and tires)
mileage/abuse car has been subjected to- 60k miles w/ less than standard amount of abuse
Based on your comment, it's a tire problem. I'm guessing an out of round issue not a blanace issue. No amount of balancing will offset an egg shaped assembly.
Go to a reputable dealer and ask them to check each assembly with a radial run-out gauge. When you find the culprit, try rotating the tire 180 degrees on the wheel. If that doesn't work, ask for an adjustment and get a new tire.
