Gears
Old Jan 19, 2007 | 02:52 PM
wyovette98's Avatar
wyovette98
8th Gear
Default Gears
can anyone help me find the best gears for my c5, I want more low end power without sacrificing a whole lot of gas mileage I was thinking 4.11s, any suggestions and what kind of performance can I expect
Old Jan 19, 2007 | 03:02 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Is it an A4 or MN6?
If it is an MN6 go with the 3.90's
3.90's leave room for more engine mods. If you end up with any kind of HP in your car, you will blow away 4.11's
If you are going to leave it stock, than you could consider 4.11's
My 3.90's are by far and away the best mod I've done.
Peace
Chip
__________________
..................Click for
Old Jan 19, 2007 | 03:32 PM
moserbe's Avatar
moserbe
A4 go with 3:42
Old Jan 19, 2007 | 03:43 PM
94legaleagle's Avatar
94legaleagle
A4 auto go w/ 3.73's and a SS 3200 or SS3600 stall converter. you won't be sorry!
Old Jan 19, 2007 | 03:44 PM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
Old Jan 19, 2007 | 05:13 PM
Phantom2007's Avatar
Phantom2007
Originally Posted by moserbe
A4 go with 3:42
I did 3:42s very happy I did not let people talk me into 3:73s
Old Jan 19, 2007 | 05:17 PM
ronniej's Avatar
ronniej
St. Jude Donor '06
A4 go with 3:42
Old Jan 19, 2007 | 05:22 PM
ktownDawg's Avatar
ktownDawg
When I started doing mods I did the long tubes and then did 3.90's, you will have alot of fun just by doing those two things
Now I add a Maggie and a 2800 stall converter. cant wait to see how it does when spring gets here.
Old Jan 19, 2007 | 05:23 PM
wyovette98's Avatar
wyovette98
8th Gear
Default more gear questions
thanks for all the great input the car is a 98 auto, pretty stock.. I am still undecided on whether to go with 3.42s or 3.73s, but say I was to go with either of those what else would I need for the install, about how much time would it take, I would like to be able to do it when I am on leave from Iraq in march,
Old Jan 19, 2007 | 05:29 PM
ktownDawg's Avatar
ktownDawg
this is also a 98 /auto, go to DTE for the rearend and spend the money for the hardened staff as well. it also a good idea to buy their brace.
Old Jan 19, 2007 | 06:12 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Do some searching=you'll find some very good advice on DIY. Read through them and decide if you can do the change over your self.
Thanks for serving
To Gears
