[Z06] Tight Turn Question
Old Jan 20, 2007 | 10:14 AM
DrRich's Avatar
DrRich
Default Tight Turn Question
I just bought a 2002 Z06 5800 miles. Car drives AMAZING! One goofy thing I'm not sure about. . . When I turn the steering wheel/tires all the way as far as possible (when I'm making a slow full circle turn at the end of my street (at 1 mile an hour), I feel a roughness to the tires, like its rubbing or flat or something. I see no other effects of this while driving normally (or even driving at 100mph plus). Anything weird here???
DrRich
Old Jan 20, 2007 | 10:25 AM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
DrRich
Probably is normal, this isnt a Caddy. The ride in this car isnt meant to be smooth. If it was a flat spot then you would constantly feel it. Go to a dealer and test drive a used Z and see if it drives the same.
Old Jan 20, 2007 | 11:03 AM
BlackZ06's Avatar
BlackZ06
What you might be feeling is the limited slip differential. When making a tight turn the inside rear wheel has to travel much more slowly than the outside wheel, and while a differential in a "normal" car doesn't resist this, the limited slip rear end doesn't handle this quite as smoothly.
Old Jan 20, 2007 | 01:20 PM
mcknjohn's Avatar
mcknjohn
Mine does this when I first start it up on a cold morning. I've always chaulked it up to the limited slip being extra grabby when it's that cold.
-John
Old Jan 20, 2007 | 03:09 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
DrRich
I get the same feeling when I back out of the garage and turn slowly down the drive, almost feels like the tire is "skipping". Never figured out what it is, and it never bothered me too much
Old Jan 20, 2007 | 03:51 PM
HisandHerZ06's Avatar
HisandHerZ06
My 03Z does the same thing down my driveway when I am turning into the street. I was waiting till I had the $100 for the deductable till I turned it in to get looked at, but it's sounding normal..........
Old Jan 20, 2007 | 05:10 PM
Bill Dearborn's Avatar
Bill Dearborn
The front tires will scrub sideways on tight turns at slow speeds. All C5s do this. I noticed it more when I had my camber set at -2.5 Vs the normal -.75.
Bill
Old Jan 20, 2007 | 05:15 PM
Goody's Avatar
Goody
Bill is right, it is the negative camber settings that these cars have for their great handling. Comes at a cost which is very slow speed scuffing feeling when turning tight corners, doing U-turns or parking.
Old Jan 20, 2007 | 05:29 PM
63Corvette's Avatar
63Corvette
I agree..............BUT, do your (stock) bushings bind and make lotsa noise when turning very slowly or backing out...when it's very cold?
Old Jan 21, 2007 | 07:13 AM
BlackZ06's Avatar
BlackZ06
Bill
Bill,
I don't understand how camber would be an issue. If anything, a radical camber number means that the tires at low speed have very little contact patch with the road. I can understand if toe in/out is radical, or if caster is set to a weird number, but please help me understand where camber comes into this (and I admit I think I understand suspension geometry, but I also know that I've got enough knowledge to be "dangerous", not neccesarily "smart") ??
Thanks,
Steve
Old Jan 21, 2007 | 10:23 PM
Kev's 1st Vette!!'s Avatar
Kev's 1st Vette!!
I just bought an '02 with 12,000 miles and I have the exact same feeling. I understand what the guys are saying about the limited slip diff., but if you guys are feeling what I am, it is exclusively coming from the front end of the car on tight slow turns (i.e. cult-de-sac). Just glad to know it's not just mine!
Why doesn't my Dad's '01 Vert do this?
Old Jan 21, 2007 | 10:42 PM
Vettez16's Avatar
Vettez16
First time it happen to me was on a cold day, though the front end was broken. Found out in talking to many other C5 owners is that this is a characteristic of the car. No Biggy!
Old Jan 21, 2007 | 11:30 PM
yellohvette's Avatar
yellohvette
if this helps ANY, here's my story...
2001 Coupe never had any issues with this on my y2k thin spokes. i then installed some z06 wheels and tires (F1 Supercars). Started doing this right after that. It is almost like the wheel is slipping at VERY low speeds and tight turns. I notice this MORE (skipping is more pronounced) when the weather is COLD but seems to happen no matter what the temp is. This leads me to believe it is something with the width of the front tires. I see no rubbing marks on the wheel wells, so I don't think it is rubbing. my guess is that it is the tires in this weather combined with the larger contact patch/camber. Does anyone have this with a different type of tire? maybe an all season/snow tire? I know the F1's are NOT cold weather tires, so I wonder if that is why we are experiencing this in January (and december, etc).
Hope that helps some. Either way, i wouldn't worry too much...it seems to be "normal".
Old Jan 22, 2007 | 10:05 AM
EB-Z06's Avatar
EB-Z06
My FRC and now the Z06 did/does that exact same thing... Another one of those "normal" GM qwarks!
Old Jan 22, 2007 | 10:38 AM
SLO VETTE's Avatar
SLO VETTE
mine's done the same thing since new, more noticable in cold temps. i don't think much of it.
Old Jan 22, 2007 | 01:41 PM
zulatr's Avatar
zulatr
Bill
I have the same thing in my 03 Z with stock wheels and tires and SC tires. It is without a doubt tire scrubbing at near lock condtions, which you (typically) only see at very low speeds. It's a function of the width of the tire contact patch, wheel offset, and some built in suspension geometry. All of which are slightly different than a regular C5, which may be why it's more obvious on our cars.
You may feel it more when it's cold because the tires actually slips (which you feel), rather that just stick and deform. Take your hot tires in a freshly sealed parking lot, and do a full locked circle at minimum speed. The front tires will leave a mark on the pavement. That's tire slip because of scrubbing.
Old Jan 22, 2007 | 03:28 PM
63Corvette's Avatar
63Corvette
Again.........I think it "may" be your suspension bushings causing the feeling in the steering wheel and ths noise....NOT the front tires slipping.
Just my opinion.
Old Jan 22, 2007 | 04:21 PM
RSCAR's Avatar
RSCAR
Good to know there are plausble explainations for this as my car does it too. Slow speed, backing out of driveway and turning wheels hard left.
Old Jan 22, 2007 | 04:30 PM
KBRVETTE93's Avatar
KBRVETTE93
my 02 does it
To Tight Turn Question
