differencail Capactiy
Old Jan 21, 2007 | 11:30 AM
rkort's Avatar
rkort
Default differencail Capactiy
i want to change my differencail oil how does it take and what would be the best, i done a search and not found a good answer.
thanks
Old Jan 21, 2007 | 12:38 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
I beleive it's 2 quarts, BUT it's pretty simple.
1) Drain the differential.
2) Put the washer and drain plug back in and secure.
3) Open the fill plug and refill. You refill until fluid starts to come out of the fill hole. THEN let it sit for a while until it stops dripping, put the fill plug back in.
Use Synthetic fluid like Royal Purples Max-Gear
With Royal Purple you do NOT have to add GM's additive to the gear fluid..
Old Jan 21, 2007 | 02:02 PM
$hawn's Avatar
$hawn
Should be a little less than 2 quarts.
Old Jan 21, 2007 | 02:18 PM
Patches's Avatar
Patches
A bit less than 2 qts. for a refill. Don't forget to add the friction modifier if the diff fluid you choose doesn't already have it added.
Old Jan 21, 2007 | 02:38 PM
Blown-Interceptor's Avatar
Blown-Interceptor
What is the friction modifier? Is that the GM additive?
Old Jan 21, 2007 | 02:43 PM
Glennm27's Avatar
Glennm27
YES
Old Jan 21, 2007 | 02:48 PM
Blown-Interceptor
Originally Posted by Glennm27
YES
I thought you did not need it with Royal Purple?
Old Jan 21, 2007 | 02:51 PM
Glennm27's Avatar
Glennm27
You thought corrrectly. You do NOT
Old Jan 21, 2007 | 02:53 PM
Blown-Interceptor
I thought so, cause you said it in your first post of this thread.
Old Jan 21, 2007 | 10:06 PM
rkort's Avatar
rkort
thanks for all the help, what do you think is the best, syn oil without the additive or reg oil with the additive,
To differencail Capactiy
