Tire sensor
Old Jan 22, 2007 | 09:02 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Tire sensor
What happens if I don't put sensors back in my new rims? Nothing? Throw a code?
Old Jan 22, 2007 | 09:15 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
You will get constant mssages on the DIC that tire pressure is an issue.
Why would you consider not putting them in????????????
Old Jan 22, 2007 | 09:51 AM
Hvymtlc5's Avatar
Hvymtlc5
Because the tires are already mounted and balanced from the seller - were C5 wheels on a show Blazer. Can't that "error message" be programmed out with a handheld?
Old Jan 22, 2007 | 11:40 AM
wamara's Avatar
wamara
Cruise-In II Veteran
It's my understanding that if your car is '01+ you can delete this with a Tech II.
Old Jan 22, 2007 | 01:19 PM
Hvymtlc5's Avatar
Hvymtlc5
I'll check it out since I'm am an 01.
Old Jan 22, 2007 | 03:15 PM
The DIC will display a warning message - you will need to hit reset each time you start up the car. "01 and above you can program the computer to prevent the message from appearing.
But, why not just run the sensors? Great safety feature.
To Tire sensor
