rear end gear ratio
Uber Waxer
if its a 6 speed, it will be a 3.42
auto, either 2.73 (GU2) or 3.15 (G92 i think)
but you check the sticker in the glove box to see which it is.
Received 19,478 Likes
'20-'21-'22-'23-'24
I asked a friend at the local Pontiac dealer to get a build sheet for my car. It is full of info including the rear end gear ratio. It shows both G90(3.15) and G92. (3.15 performance axle ratio). I assume from this it is the G92 as shipped. FYI it also shows the MXO(4-speed auto w/overdrive) and M30(4-speed electronic auto with OD).
actually it's 75 mph in 3rd with an A4.
That's very strange as I have a 3:15 diff and at 3150rpm I'd be doing well over 100mph!!!!!!!!!!!!
