battery tender questions
Old Jan 23, 2007 | 07:29 AM
ayeroff's Avatar
ayeroff
Default battery tender questions
Is there a particular battery tender that most people recommend for long term (7 months) storage?
What companies or forum vendors have the best deals?
Is it better to remove the battery from the car when hooked up to the tender for that long, or is it alright to hook up the tender with the battery still in the car?
Thanks for the help.
Old Jan 23, 2007 | 07:36 AM
Corvette1996LT1's Avatar
Corvette1996LT1
Yes, you can leave the battery hooked up in the car. Battery tenders will charge just fine without damage to the car's electrical system. It is a float charger so once it tops off the battery it will shut off.
I have a battery butler and it works very well.
http://www.lectriclimited.com/battery-butler.htm
Old Jan 23, 2007 | 07:45 AM
moserbe's Avatar
moserbe
Leave the battery in the car with the tender hooked up. Everything is automatic so rest assured that you're in good hands with the "battery tender plus".
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
I have had great reults with the Batttery Tender Plus 12V. I am using now for my 4th season and has been perfect.
I now use them on 2 different cars. I bouyght a second unit last fall tfor the 2nd car that also sits idle for long periods.
Battery Tender Plus
Old Jan 23, 2007 | 07:47 AM
JD's C5's Avatar
JD's C5
battery butler is pretty good-they charge the battery as needed and are good for long term storage. I have been using one for 3 years and no problems.
Old Jan 23, 2007 | 08:11 AM
Glennm27's Avatar
Glennm27
The Battery Tender does all the work. It is not the same as a trickle charger. The B-T will charge the battery then settle back and turn itself back into charge mode when and if the battery falls down below 80% full charge. It does NOT keep a constant charge going.
Old Jan 23, 2007 | 11:15 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have the deltran Battery Tender weather proof model. I have used it for the past 3 winters. Works great.
Old Jan 23, 2007 | 12:07 PM
GaryS52's Avatar
GaryS52
I just purchased a 1999 with 33,000 miles on it.. Do I need a battery tender if it will be stored
till late March or early April?
Old Jan 23, 2007 | 12:12 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Here you go...
We've sold 300+ of these so far this winter. IMHO they are the
best around.
http://www.customcorvetteaccessories...rycharger.html
Peace
Chip
__________________
..................Click for
Old Jan 23, 2007 | 12:39 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
been using this for 3+ years - works great and the money I saved (versus others) went to more mods....
http://www.harborfreight.com/cpi/cta...emnumber=42292
Old Jan 23, 2007 | 12:52 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I have used the Battery Tender Jr over a few winter months when i Vette sits inside my garage. It works fine in keeping the charge on the battry.
Old Jan 23, 2007 | 06:22 PM
The Deltran Battery Tender Plus would be a good choice (I have this one). You do not need to remove the battery from the car - just hook it up and let it be. Does a great job keeping the battery charged up. About $60 from any vendor.
Old Jan 23, 2007 | 06:52 PM
SteveDoten's Avatar
SteveDoten
I'd remove the battery
Old Jan 24, 2007 | 01:04 PM
ytwokc5's Avatar
ytwokc5
That's what I'm using. Picked up two of them, one for the vette, one for the John Deere!
Old Jan 24, 2007 | 06:48 PM
rico750sxi's Avatar
rico750sxi
I have been using a Battery Tender Jr. for the last 2 years on the GTO then the Z. Works as intended, I would recommend it.
Old Jan 24, 2007 | 06:52 PM
photoguy's Avatar
photoguy
No as long as you start it up every couple weeks and let it run for 10min or so.
photoguy's Avatar
photoguy
Go to AutoZone. They sell them for 29.99
To battery tender questions
Old Jan 24, 2007 | 07:17 PM
M_T_0's Avatar
M_T_0
walmart has the black and decker unit for less than $20 down here, I have like 5 of them on diffrent things, they also have a cig lighter adapter to make it easy.
More Than Zero
Old Jan 25, 2007 | 10:48 AM
GaryS52's Avatar
GaryS52
Thanks photoguy. I am about an hour west of Pittsburgh. Can't wait till nicer weather finally gets here to stay. I have had my car for about a week, and it is killin me to just watch it sit in the garage. Sure is pretty though. :-)
Old Jan 25, 2007 | 11:08 AM
birch64's Avatar
birch64
i bought the same one from harbor freight last year on sale for $5.99 and works great.
