{Throwing CODES}
Old Jan 23, 2007 | 10:31 AM
CBLeitch9's Avatar
CBLeitch9
Default {Throwing CODES}
I need your guys expertise. My car's check engline light is on; I have checked the codes through the DIC and the only ones that come up are 10-PCM P1416 H C and A6-SCM B2605 H. Everything else says "no codes". According to the list of codes I have, the 10-PCM P1416 H C code refers to AIR system Bank 2 and the A6-SCM B2605 H code refers to Seat Front Vertical Position Sensor Failure.
Do those codes sound like something that would make the check engine light come on? Or, do I have to do the dreaded thing and take it in to the shop or stealership? Please let me know what you guys think I should do.
Thanks!
Old Jan 23, 2007 | 10:50 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
the B2605H code is a history code so I would probably reset that one and see if it comes back.
the P1416C H code which is current is causing the check engine light to come on.
here try reading this and see if it helps
http://forums.corvetteforum.com/show...ighlight=P1416
