[Z06] Z06 Rims
Old Jan 24, 2007 | 11:03 AM
bsteinkamp's Avatar
bsteinkamp
Default Z06 Rims
Will the rims from an 07 Z06 (F18 X 9.5 & B19 X 12) fit on a 04 Z06??
Old Jan 24, 2007 | 11:07 AM
bsteinkamp's Avatar
bsteinkamp
One more question will the tire air pressure sensors work on the 04 Z06??
Old Jan 24, 2007 | 12:24 PM
PA Z06's Avatar
PA Z06
Im almost positive the will fit no problem, im sure someone will chime in, the rears might stick out a tad, but the sensors will not work, z06s were not equiped with tire pressure sensors.
Old Jan 24, 2007 | 07:18 PM
azmusclecar's Avatar
azmusclecar
I may be mistaken but I believe you can have the tire pressure monitoring system enabled on a ZO6 I believe the dealer does it and if I recall, it's called like Tech II.
Old Jan 24, 2007 | 07:59 PM
Red ZEE06's Avatar
Red ZEE06
I'm not sure if C6 pressure monitors are the same as c5 sensors. I bought a set of c5 sensors from Fred Bean which I'm going to mount on C5Z06 rims. The dealer confirmed he can activate the tire pressure monitoring system with a Tech II
There are numerous postings on the site that go into all the details.
You don't want to use the tire sealer goop if you get a flat because it will ruin the sensor. That's the reason that they were not originally installed on the C5Z06!
Old Jan 24, 2007 | 10:15 PM
bsteinkamp's Avatar
bsteinkamp
So will they fit without any modifications!
To Z06 Rims
