Memory 1 & 2, settings help
Old Jan 25, 2007 | 01:27 AM
Mach2's Avatar
Mach2
Default Memory 1 & 2, settings help
98 C5 new owner that can't seem to be able to figure out how to set the Memory 1 setting for myself and the Memory 2 setting for the Wife. Do you start the car, adjust seat, radio, auto temp, etc. then hit the Memory 1 button on the drivers door or just turn the key to Accessory?
Appreciate the help
Mickey
Old Jan 25, 2007 | 02:14 AM
PierEagle's Avatar
PierEagle
The way I doed it..start car, leave in park, set seat, radio, mirrors, hvac, etc., where I want it. Then press and hold button #1. The light above the button will glow steady for one second and then flash when the settings are achieved. Button #2 can be programmed using the same procedure. You can also program for a third person by doing the settings and then pressing buttons 1 and 2 at the same time. If you have two key fobs, the first one that you program will save the button 1 settings. The 2nd fob programmed will have the button 2 settings. Do a search on fob programming.
If you don't have one, I would suggest you buy an owner's manual. There is a whole bunch of useful info in there. New ones can be bought at www.HelmInc.com. They are the official printers. Cost about $25 or $30.
Cheers
Old Jan 25, 2007 | 10:45 AM
Mach2's Avatar
Mach2
Thanks alot. I'll get the Owners Manual and check out the fob programming.
Mick
Old Jan 25, 2007 | 02:12 PM
bighank's Avatar
bighank
Default owners manual
Don't remember WHO but one of the vendors has an ONLINE OWNERS MANUAL for each year for C5s. Someone will let us know WHOM.
Old Jan 25, 2007 | 02:27 PM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
If you go to mygmlink.com and register your vehicle you can access the owners manual on-line.
Old Jan 25, 2007 | 06:33 PM
Mach2's Avatar
Mach2
Thanks for the help Folks, got the Owners Manual out and read up on setting the Memory buttons and fob Training.
Mick
Old Jan 27, 2007 | 02:36 PM
bighank's Avatar
bighank
Default GM owners manual
Thanks for the link but I found one of the VENDORS who advertises on here that has the GM Manual as a downloadable ADF file. No registration needed. BIGHANK
Old Jan 27, 2007 | 04:09 PM
fixvet's Avatar
fixvet
R T F M
Old Jan 27, 2007 | 05:47 PM
oldschoolvette's Avatar
oldschoolvette
good luck
To Memory 1 & 2, settings help
