Tire Plug Kit
Old Jan 25, 2007 | 01:08 PM
FRED HAMBLE's Avatar
FRED HAMBLE
Default Tire Plug Kit
Does anyone knopw the part number for the Snap on tire plug kit? Can U order it directly from Snap on or do U need to locate a dealer?
FRED
Old Jan 25, 2007 | 07:44 PM
FRED HAMBLE
ttt
Old Jan 25, 2007 | 09:18 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Fred, I spent a good 15 minutes in the Snap-On website and don't come up with a tire repair kit. I have a good one that I bought off the "auction site" for under $30 in a red "Snap-On" looking Delrin case.
Old Jan 25, 2007 | 11:15 PM
FRED HAMBLE
what did you search under Snap on or just tire repair kit??
FRED
Old Jan 26, 2007 | 12:29 AM
gpotski's Avatar
gpotski
I've heard good things about "safety seal."
http://www.safetyseal.com/
A little example of the kit's use...
http://www.4x4review.com/tech/safety-seal.asp
Old Jan 26, 2007 | 07:45 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Safty Seal
I bought this product when I switched to non-run flat tires. I had to use it a few months ago. Since then I have done a few spirited runs with no problems. I know an inside patch is the right way to repair a tire, but in an emergency, this is a real easy fix.
Old Jan 26, 2007 | 07:52 AM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
Plug patch combo pulled through the inside of the tire
Old Jan 26, 2007 | 10:16 AM
white top's Avatar
white top
take a look at J.C. Whitney catalogue they have areal interesting plug kit for about $30.
Jerry
Old Jan 26, 2007 | 12:57 PM
78-Bandit's Avatar
78-Bandit
Active Streak: 90 Days
they sell plug kits at most all autopart stores. Also, Sears make a nice small compressor. Just make sure you pack a set of good needle nose pliers. The patct kit is no good if you can't get the nail/screw out.
Old Jan 26, 2007 | 11:05 PM
FRED HAMBLE
ttt
Old Jan 26, 2007 | 11:11 PM
hk940's Avatar
hk940
yea. no brainer. get a cheep one at the autoparts store.
or go all out and buy one with a t handle rasp and an "eye". you get a few plugs and some glue.
Old Jan 27, 2007 | 08:15 PM
RonJ's Avatar
RonJ
I carry a plug kit and compressor in my C5, have never used it on the 'vette though.
One day, a tire was down on my pick-up so out came the plug kit from the 'vette.
What a S.O.B. to get the plug through the hole. I used the rasp and cleaned the hole out real well hoping to enlarge the hole, still had to use a hammer to get the plug into the tire. Guess it's the steel belting in the tread area.
Not looking forward to using it on the 'vette!!!
RonJ ...
Old Jan 27, 2007 | 08:19 PM
Corvette Don's Avatar
Corvette Don
RonJ ...
My r/r tire kept getting low so i pulled it off the car to find a small nail, I had to drill the hole bigger to get a plug in there no more air leaks now
To Tire Plug Kit
