Pic request: BPP headlights
Old Jan 25, 2007 | 09:00 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
Default Pic request: BPP headlights
All color cars, multiple angles please.
TIA!
Vaughn
Old Jan 25, 2007 | 09:49 PM
efhardwork's Avatar
efhardwork
Hope this will help. Later Ernie
They do get a little dusty under the lense.
Old Jan 26, 2007 | 07:32 AM
JohnTheStigGalt
Thanks Ernie! Any shots from the side level with the car?
Old Jan 26, 2007 | 11:01 AM
DPG's Avatar
DPG
St. Jude Donor '06
i bought the car with these on. The stock lighting on these sucks!
This is after i added the HIDs, still working on finishing them
Old Jan 26, 2007 | 12:57 PM
JohnTheStigGalt
Originally Posted by DPG
I REALLY like this angle! Sometimes I see the BPP lights and they look bubble-like, and others I see look more flush. Is this a difference in mounting bracket adjustment? I'm going for the more flush look, like in this picture. I also don't like the retangular bulb, so if I go this route, I'd do HID's and probably do a custom carbon fiber surround.
Anyone have them with a Tigershark front end?
Old Jan 26, 2007 | 01:06 PM
Rick@Moroso Performance's Avatar
0Rick@Moroso Performance
Former Vendor
From: Moroso Performance, Guilford, CT, 203-453-6571
Old Jan 26, 2007 | 01:18 PM
DPG's Avatar
DPG
St. Jude Donor '06
they are a little bubbled, but not to the point where you notice it much. I had to cut into the fender to get the bulbs to fit.
original
modded
there is some adjustment available but not too much with the lens height
Old Jan 27, 2007 | 09:49 AM
stormrider's Avatar
stormrider
Is the heat from the HID's causing any problem and do you have pics on how you installed them in the BBP's? Your Vette is very !
Old Jan 27, 2007 | 07:49 PM
JohnTheStigGalt
Very cool DPG. I'm wonding whether I should just build something from scratch. The only difficult part would be the lexan. I've no objection to cutting the inder fender. And I don't mind the slight bubbled look of the BPP lexan. Even WITH the rectangular light of which I'm not fond, these are still the nicest looking C5 headlights IMO.
Old Jan 28, 2007 | 04:13 AM
DPG's Avatar
DPG
St. Jude Donor '06
Thanks for the compliments. Its still a work in progress because ive been slacking on these. they do get very hot, but with the fans in there its not bad. Very hot to the touch though. i havent had any issues so far other than the light reflected off the lens burning marks into the bottom cover. (kinda like how a magnify lens burns ants) I'll check to see if i have a pic to show you what im talkin about.
You can definitly build yours from scratch, thats practically what i did. What you can do is just order the lenses from breathless performance. Last time I check I think it was 125 for one lens.
stormrider, im not sure i follow on your second part of the question about the install.
Old Jan 28, 2007 | 04:16 AM
DPG's Avatar
DPG
St. Jude Donor '06
here are some closer pics with the covers on.
i cant seem to find a pic of the burn marks. I'll try to take some on monday night and post them.
Theres also someone else on here that has made his from scratch and he bought i think the c5r lenses, not sure on which ones, but his look great. I think his forum name is benelliwang
To Pic request: BPP headlights
