Battery Trickler Question
Old Jan 27, 2007 | 12:25 PM
csc67's Avatar
csc67
Default Battery Trickler Question
Living is an area that gets a lot of snow, I have put the vette in the garage for storage. Purchased a battery trickler, but don't know if I should put the negative cable on the negative battery post OR ground it via the frame
Let me know your opinion
Chris
Old Jan 27, 2007 | 12:28 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Let me know my opinion
Chris
Either way is fine
Old Jan 27, 2007 | 12:30 PM
hotwheels57's Avatar
hotwheels57
It also depends on the type of battery you have...a lead acid battery will out gas whereas an OPTIMA will not. Connecting to other than the battery itself is suggested to avoid the potential explosion of the out gas.
Old Jan 27, 2007 | 01:18 PM
steck's Avatar
steck
if you're battery is a 'negative grounded battery' , which i believe it should be...
than you attach your negative clamp to your frame etc...
(atleast that's what my 'floater' charger advises in the manual)
Old Jan 27, 2007 | 09:47 PM
rrichar2591's Avatar
rrichar2591
I hook up my maintainer directly to the battery posts. I thing it's suggested that when you hook up the battery, put the positive clamp on first. When unhooking take the positive off last.
Old Jan 27, 2007 | 09:49 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I hope you meant a float charger, not a trickle charger....
Old Jan 27, 2007 | 10:11 PM
moserbe's Avatar
moserbe
I hook my battery tender directly to the negative terminal.
Old Jan 27, 2007 | 10:17 PM
Gonzo's Avatar
Gonzo
Old Jan 28, 2007 | 02:37 AM
doug doo wop's Avatar
doug doo wop
Mine is a floater and it tells you not to clamp on the battery, just any unpainted metal. It should tell you in the directions.
Old Jan 28, 2007 | 07:59 AM
65GGvert's Avatar
65GGvert
"Let me know my opinion
Thanks"
That's what I had to tell my wife, when I was married.
To Battery Trickler Question
