HELP..cyberdine inserts wont stay
Old Jan 28, 2007 | 01:18 PM
finallystylin's Avatar
finallystylin
Default HELP..cyberdine inserts wont stay
got inserts for dash and rear. got dash to stick with a little dab of super glue. Rear wont stay on. followed all directions to the letter. Has anyone used another type of adhesive to help them stay on the outside?
Old Jan 28, 2007 | 01:45 PM
NJ Vette Guy's Avatar
NJ Vette Guy
Mine are not Cyberdyne, but.....
Did you clean out all the wax build up, with isopropyl first?
Mine fell out after a while, so I bought some 3M double sided tape, removed all of the letters and reapplied.
They haven't been a problem since.
Old Jan 28, 2007 | 05:14 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I'd clean out the slots with Dawn and water, rinsing them out good, then use the alcohol. Then I'd get some new 2 sided 3m exterior tape
Old Jan 28, 2007 | 06:12 PM
I don't have the Cyberdine inserts, but when I installed a set of inserts on my car, I went over the area a few times with rubbing alcohol - cleaned it really well. Stuck the inserts on and they have held tight ever since. Maybe call Cyberdine and explain the problem and get their recommendation.
Old Jan 28, 2007 | 07:11 PM
finallystylin
If not cyberdine, which ones did you use that worked so well?
Old Jan 28, 2007 | 08:49 PM
LTCHAPPA's Avatar
LTCHAPPA
Get some 3M spray adhesive on the back side of the letters and reaply. You could get it at an art supply store.
Old Jan 28, 2007 | 09:14 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Had same problem. Was told to mild soapy water to clean area with first. Seems to have done the trick, no problems now. Also becareful not to touch sticky are with fingers (oil).
Old Jan 28, 2007 | 10:06 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
I have Cyberdyne steering wheel and rockers. Got domed rear letters 2yrs ago forgot fom where. Prep is everything.
Old Jan 29, 2007 | 12:26 PM
finallystylin
Thanks guys. Gonna prep again, as well as using 3m spray.
Old Jan 29, 2007 | 01:33 PM
jrose7004's Avatar
jrose7004
I followed Alex's instructions and I haven't had any trouble, their stuck on there really well!
Old Jan 30, 2007 | 12:53 AM
PierEagle's Avatar
PierEagle
Did the same cleaning step with mine. Only additional step; after they were applied I set a hair dryer on medium and slowly moved it over the area for about 3 minutes or so.
Old Jan 30, 2007 | 01:17 AM
BrianWe's Avatar
BrianWe
Hit or miss in my experience. Steering wheel decal is awsome, but the airbag one needs superglue. I cleaned it multiple times with alchohol before (bad prior experience with airbag stickers) and it still didn't help. Problem is the fit is just a bit off.
Old Feb 6, 2007 | 05:33 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
denatured alcohol............
Old Feb 6, 2007 | 08:37 AM
mike348's Avatar
mike348
Never could get the air bag stickers to stay put. the covering on it seems like some type of rubber.
To HELP..cyberdine inserts wont stay
