[Z06] Rear Diff Leak.......No More!....
Old Jan 28, 2007 | 09:12 PM
DA KAR's Avatar
DA KAR
Active Streak: 90 Days
Default Rear Diff Leak.......No More!....
Thought I had the driver's side diff leak-seen a little wetness around the diff and not coming from the vent tube.Checked the bolts on the diff and the one at the 3 oclock position I got a quarter turn out of her and my leak stopped.The rest of the bolts were tight except that one........Check that bolt before doing the gasket repair.
Old Jan 28, 2007 | 09:50 PM
Z28TOZO6's Avatar
Z28TOZO6
Is there a recall for bad coverplates?
Old Jan 31, 2007 | 09:42 PM
DA KAR's Avatar
DA KAR
Not sure if there is.
Old Feb 1, 2007 | 09:18 AM
QuikZilver's Avatar
QuikZilver
Wish mine was that simple. Already had GM reseal the transmission and diff last year, under warranty. Have a new leak between the tranny and torque tube. Hopefully, my Z will be going under the "knife" tomorrow. Getting some goodies installed at the same time. With the rear out it is a great time to add a hardened output shaft and DTE Brace.
To Rear Diff Leak.......No More!....
