Simple answer is different intake manifold. The Z06 was made in 01 and it came with a LS6 engine which is shared by the same block with LS1. So they started putting the more free flowing LS6 intake manifold on all LS1's and it made approxmitely 5hp. You see more gains switching over to it if you have after market heads or cams. Little gain is seen on stock internals.
Didn't they change the catalytic converters to the California type used in earlier years? With that in mind, that 5hp difference would actually be higher if the breathing was like the 98-2000?
Yep, on the plus side, the 01 and later C5s had the larger LS6 intake, the larger MAF, and the better flowing cast iron exhaust.
On the negative side, the 01 and later C5s had the addition of the pre, or "pup" catelitic convertors added, as well as a smaller camshaft than the 2000, which had the largest lift and duration of all LS1 camshafts. (Only the 2000 C5s bound for east or west coast delivery, had the addition of the pre or "pup" cats in 2000.) Engineers at GM estimated that the pre/pup cats reduced hp by about 5hp, so it's safe to assume the addition of the LS6 intake manifold and the larger MAF, resulted in an addition of 10 hp, and the corresponding increase in torque numbers also noted.
If you follow all of this, it also means that the 2000 C5s not eqipped with the pre/pup cats, but which included the larger camshaft, have a hp output closer to 350 than the advertised 345.
