Please HELP!!!
Old Jan 29, 2007 | 09:03 PM
dbirdz06's Avatar
dbirdz06
Default Please HELP!!!
How do I separate the lower control arm and the upright??? Everything is unbolted, and I cannot get them apart!
I've tried using a 2x4 and a hammer to hit the LCA, no luck. I've wiggled, jiggled, and cursed. I'm out of ideas! Please help me, or I won't have a car to get me to work tomorrow, aw shoot!
Old Jan 29, 2007 | 09:05 PM
dbirdz06's Avatar
dbirdz06
FYI, I am trying to replace the lowering bolt that you see missing in the second picture.
Old Jan 29, 2007 | 09:26 PM
astley101's Avatar
astley101
I did something like this on a BMW. You need to get something,its like a fork with only 2 prongs, and you slide it in between the joint.They have them at Auto Zone/Home Depot places.
Old Jan 29, 2007 | 09:41 PM
Rocket02's Avatar
Rocket02
You'll need a Fork for this. Get a cheap one. I've used mine 5 times in 10yrs and 3 of those times was for home remodeling. Even easier is with the assistance of a air chisel but fork much cheaper route.
Old Jan 29, 2007 | 09:42 PM
Old Man in a C's Avatar
Old Man in a C
Support the a-arm from below ... jack stand or jack
Put the nut back on the ball joint stud (to protect the threads)
Give the stud a GOOD rap with a 3 lb hammer.
Should drop out.
If you use a fork, you'll run a good chance of destroying the boot and end up replacing the ball joint
Old Jan 29, 2007 | 09:52 PM
astley101's Avatar
astley101
Ok the fork I was referring to is called a tie rod separator just so that you know. They come in different sizes,if your careful you shouldn't mess up the ball joint.
Old Jan 29, 2007 | 10:13 PM
dbirdz06's Avatar
dbirdz06
Well, I ran out of time so I bolted everything back up. Thanks for the responses, I was getting worried. I've removed it before and all it took was a little bit of up-and-down, then side-to-side movement and eventually it just broke loose and the control arm fell. No clue what the deal was this time. I may have ripped off some of the threads on the bolt that runs through the upright from banging on the thing. Actually I'm positive that I did but I bolted everything back together and it seemed fine. Maybe I'll have better luck with it next time I try.
Still up for ideas to make that easier though...
Old Jan 29, 2007 | 11:39 PM
94legaleagle's Avatar
94legaleagle
Put the nut back on the tie rod end - screw nut down till it's flush w/ top of threads - take a block of wood to protect the threads, and place block on top of nut/tie rod end - use a BIGGER hammer - no, I'm not kidding or being smart - get a BIGGER hammer than what you are using - you will be surprised that hitting with a Bigger hammer might do the trick -
or, get the tie rod seperator a/k/a "pickle fork" which has been mentioned and use that
I removed mine a month or so ago for a head / cam swap so I could get the steering sector out - I didn't think it was going to budge either, so I got the proverbial bigger hammer, and hit harder w/ the bigger hammer - it came out
Old Jan 30, 2007 | 09:42 AM
dbirdz06's Avatar
dbirdz06
Yeah, I was just using a typical nail hammer. Maybe I need a sledge hammer or something!
Old Jan 30, 2007 | 01:30 PM
94legaleagle
Typical nail hammer is not big enough - not enough mass behind it to push the tie rod end out
Old Jan 30, 2007 | 02:26 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
.....................CAM..............
Old Jan 30, 2007 | 02:43 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Should drop out.
And you DON'T want to do that!
Old Jan 30, 2007 | 03:43 PM
cadallante87's Avatar
cadallante87
I find it easier to use the fork without air chisel. Air chisel is harder to control and usually wrecks them. Fork with hammer and 3 good blows does the trick for me.
Old Jan 30, 2007 | 08:23 PM
dbirdz06's Avatar
dbirdz06
Hahaha! Don't worry, I'm about to talk myself into that R1.
Old Jan 30, 2007 | 08:57 PM
mojo1's Avatar
mojo1
Quoting my wife after she drove the car the last 2 days "The cam is badass!"
But to this thread , I had the same problem changing ball joints on a truck , I put the jack on the outer edge off the frame, and a few smacks with the hammer and it came apart.
Old Jan 31, 2007 | 12:16 AM
jbauch357's Avatar
jbauch357
Stay away from the pickle-fork, it was a decent idea but will cause more harm than anything in this situation - unless you want to replace the ball joint.
Get a large brass hammer, I prefer either a 3lb or 5lb version for this sort of thing. Take out all the bolts you had out before and the break loose the lower ball joint nut, back it off until it's a couple threads off it's seating surface. Hit the lower control arm HARD from the side a few times and then check to see if it's broken loose. If that doesn't do it get somebody to put pressure on the lower control arm and pull down on it while you smack it with the hammer.
Basically it's a compression fitting that needs to be jarred loose, when that happens the rest is gravy...
Old Jan 31, 2007 | 01:04 PM
dbirdz06's Avatar
dbirdz06
Just bought a 3 lb hammer last night at Lowe's. That and a piece of wood should do the trick. I'm gonna tear it back down tonight and see what damage I can do
To Please HELP!!!
Old Jan 31, 2007 | 01:16 PM
94legaleagle
Remember, nut on the end till threads/end of tie rod are flush, and keep your fingers OUT of the way!
Old Jan 31, 2007 | 04:43 PM
99MAGKOOP's Avatar
99MAGKOOP
Old Jan 31, 2007 | 04:58 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It looks like this and it's called a pickle fork!
http://cgi.ebay.com/ebaymotors/Pickl...QQcmdZViewItem
Thanks,Matt
