wiper refills
Old Jan 30, 2007 | 12:44 PM
istsme98's Avatar
istsme98
Default wiper refills
What brand of refills does everybody use? The gm ones suck seems I have to replace them every few months or so.
Old Jan 30, 2007 | 12:57 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Just replaced mine with the Anco , they work great and were very cheap.Been raining here for what seems like for ever!
Old Jan 30, 2007 | 01:13 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Jan 30, 2007 | 01:16 PM
kenzo's Avatar
kenzo
piaa silicon blades. I have found that they last longer, do a better job,and thre is no noise.
Old Jan 30, 2007 | 01:22 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
This is what I am going to use when I need replacement blades
"TRICO, the top name in wiper products has teamed up with DuPont Teflon®, the world's most slippery substance, to create the ultimate premium wiper blade. The many unique attributes of Teflon® transfer extremely well to wiper blades - and TRICO is using these advantages to help create the blade of the future. A blade that wipes smoother and lasts longer.
The TRICO Teflon® Blade combines the selling power of a major household brand with one of the world's most popular names in wiper blades.
In addition to the benefits of Teflon®, this premium blade also features an extra-thick, extra-durable metal superstructure that is riveted at vulnerable contact points. The exclusive wiping edge with Teflon® resin provides longer life and a smoother wipe. And the pre-attached adaptor is designed to fit 95% of vehicles directly.
Check our online catalog to find the correct Teflon® Blade for your vehicle.
Then go to our Where Sold page to find where you can purchase Teflon® Blades.
Need help installing Exact Fit wiper blades on your vehicle? We have included video installation clips and detailed instructions to show you how. "
www.tricoproducts.com
Old Jan 30, 2007 | 01:30 PM
7898VETTMAN's Avatar
7898VETTMAN
I Use Motorcraft Aka Trico And The Orange Washer Fluid With Rain X.
Old Jan 30, 2007 | 01:35 PM
istsme98's Avatar
istsme98
Thanks for info
Old Jan 30, 2007 | 01:44 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Nice post thanks.
Old Jan 30, 2007 | 02:33 PM
xwing's Avatar
xwing
I don't think I've ever changed the wipers in my 2002.
Old Jan 30, 2007 | 02:35 PM
B-ras's Avatar
B-ras
I put a set of these on last year and they have worked quite well. I used to use Bosch but these seem to drag less.
Old Jan 30, 2007 | 02:40 PM
C5FORFUN2's Avatar
C5FORFUN2
WIPERS?!?! we don't need no stinkin' wipers!
Actually I avoid using them unless I get caught in a monsoon. I just keep a fresh coat of Rainex on the glass. My blades last for ever.
Old Jan 30, 2007 | 02:46 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
RainX and 75 = no need for wipers.
only kidding.
When I bought the Vette the WS smeared when it rained etc. New blades did nothing. I replaced the blades and tried the old Rolls Royce Steelwool but it was still smearing.
I ended up steaming the window using a steam squeege and you would not believe the crap I wiped off. RainX and Trico and it's great.
Old Jan 30, 2007 | 03:15 PM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Same here.
In fact, I think I've only used mine about 3 times in all that time.
Old Jan 30, 2007 | 03:36 PM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
Wiper blade replacement? Don't you have to raise the hood to change them?
Should I have call a mod party and get a few cases of beer for the change?
Last but not least. Any HP gain for those slippery teflon ones?
Old Jan 30, 2007 | 03:37 PM
Tom/99's Avatar
Tom/99
I seem to be using mine way to often.
Old Jan 30, 2007 | 03:47 PM
Lightgomez's Avatar
Lightgomez
I dont think I got the "wiper" option on my car....I got one of those "melts if water touches it" vettes. Hahaha!
Just kidding, Anco would be my preference as well.
Old Jan 30, 2007 | 03:49 PM
Zoomfast's Avatar
Zoomfast
Try the Bosch Ion blades. Just make sure you get the correct blade for each side as they are a unidirectional installation.
To wiper refills
Old Jan 30, 2007 | 04:20 PM
v.vet's Z06's Avatar
v.vet's Z06
Before replacement unless they are damaged, you might try wiping them off with some windshield washer fluid on a paper towel. It's amazing how long I can make a pair of wiper blades last by cleaning them as often as I wash my cars.
Old Jan 30, 2007 | 05:02 PM
diyguy's Avatar
diyguy
I've taken mine off and run thru the dishwasher. They work just like brand new again! (unless the rubber is actualy torn away or damaged).
Otherwise, Anco if/when they are replaced.
Old Jan 30, 2007 | 11:23 PM
lawZ's Avatar
lawZ
never have turned mine on,I guess they work... ?
