memory seats??? help
Old Jan 30, 2007 | 04:07 PM
Marcs c5's Avatar
Marcs c5
Default memory seats??? help
I just got my new to me 2003 Z06 last night and don't have a owners manual for it. The problem is it has to many features that require some learning and getting use to. So can some one tell me how to program these seats? I do have both key fobs and noticed they were numbered, if that matters.
Old Jan 30, 2007 | 04:16 PM
VET IT B's Avatar
VET IT B
I,m not certain but I didn't think that the Z came with memory seat feature. If it did there should be 2 memory buttons on the drivers door panel. Someone else will chime in with corrections. Mark
Old Jan 30, 2007 | 04:18 PM
65GGvert's Avatar
65GGvert
Set your mirrors, a/c, radio presets, seats where you want them for driver #1, then press and hold the memory 1 button (on the door) until it flashes. Then your # 1 fob will select those settings when you unlock the door with it and put the key in the ignition. Then if you want a different setting for the other fob, set those same options and hold the #2 button (on the door) till it flashes. When you open the door with the #2 fob those will be set for you. With either one, when you take the key out, the seat will retract automatically.You can actually set a third setting (which I do) with the seat and steering wheel all the way retracted and hold both the 1 and 2 buttons on the door. Then when you want to get out with the key in the ignition, you can push 1 and 2 together on the door and the seat and wheel will retract for easy exit. I still suggest you get an operator's manual, lots of good info in there.
Vassili's Avatar
Vassili
set the seats, a/c, radio to where you want then press and hold the #1 button until it stops blinking. your done.
To memory seats??? help
