flush taillamp kit?
Old Jan 30, 2007 | 11:27 PM
88sk's Avatar
88sk
Default flush taillamp kit?
who has the best kit ,seen some on ebay ,dont know if they come with the seals ?
Old Jan 31, 2007 | 04:31 PM
88sk's Avatar
88sk
NOBODY has flushmounts ??
Old Jan 31, 2007 | 05:45 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Don't buy the kit, just do it yourself
Flush Mounted Tail Lights
(6) 1" L X 1/2 W X .194" Hole Size Nylon Spacers
(6) 1/4" L X 1/2" W X .194 Hole Size Nylon Spacers
(8) #8 x 2" Zinc Pan Head Screws
(1) Frost King Rubber Foam Weatherseal 3/8" W X 5/16" Thick x 10' Long (Adhesive backed)(I got the black weather stripping)
Simply unscrew tail lights, clean, put weather stripping around the tail light (where the red casing meets the black casing of the light) insert new screws and spacers on back side, screw back into mounting hole.
-The two center lights get one 1" spacer on each screw.
-The outside lights get three 1/4" spacers on each of the outer most
screw
-The inner screw on the outside most lights get one 1" spacer.
-Fit so the weather stripping looks good and screw them back in!
1" spacers $4.77
1/4 Spacers $3.42
Weather stripping $3.98
Pan head screws $.98
Peace
Chip
__________________
..................Click for
Old Jan 31, 2007 | 05:54 PM
88sk's Avatar
88sk
I emailed 1 of the sellers (powerselling)they said there is no stripping cause theyre kit (laugh) fits tight BS,so if I wash my car you gonna tell me no water is gonna get in ,what are they smokin?
Old Feb 9, 2007 | 03:56 PM
88sk's Avatar
88sk
ok I got the kit from ebay seller "powerselling"thought there would be just a little of work from them ,it has 8 black philips head screws(instruction say torx head),6 pcs. 1'' long plastic& 2, 3/4 " pieces of plastic thats it ,they want $15 plus s&h ,I offered 10 plus s&h ,what a joke at that price also,I got a pic if any1 can post it for me.
Old Feb 9, 2007 | 04:35 PM
Kale's Avatar
Kale
you can use thin rubber weatherstripping available at most car parts stores to seal the back of the lights. Less than $10 iirc.
you can also buy the 'tail light seal kit' from Southern Car Parts for $25 I believe, if you want it in pre-cut lengths.
To flush taillamp kit?
