just stalled..
Old Jan 31, 2007 | 05:30 PM
dwarmenzerk's Avatar
dwarmenzerk
Default just stalled..
hey guys been ahving a problem with the car lately with it cruising, it was jumping around between 200-400 rpm while on cruise or 3/4 throttle. But on WOT it was fine.
I was on my way into class and i stall while im waiting to turn into parking lot! It wouldnt start for about 5 - 10 mins after numerous trys and seeing white smoke coming out the tail pipes I get out and check engine. Everything appears to be fine, i check below because i smell something burning, oil is my first impression i cehck the oil and then coolant, both are fine.
I did notice that when i was coming over to the college that my car wouldnt give me an oil temperature. It was saying 'low' oil temperature. Any idea what this could be guys thanks!
Old Jan 31, 2007 | 05:44 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
maybe the oil sending unit is bad or leaking ? C5s are bad with this problem but not sure that this would make the car stall though .
Old Jan 31, 2007 | 05:54 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Old Jan 31, 2007 | 05:55 PM
dwarmenzerk
ive heard this problem before.. perhaps some more input.. thanks tho.. and i already did think of this!
Old Jan 31, 2007 | 05:59 PM
Jet-Jock's Avatar
Jet-Jock
Did you check to see if a code was set?
Old Jan 31, 2007 | 06:26 PM
dwarmenzerk
i checked, only code is a p0154
Old Jan 31, 2007 | 08:50 PM
dwarmenzerk
P0118 Engine Coolant Temp (ECT) Sensor High Voltage
P0118 Engine Coolant Temperature (ECT) Excessive Time to Closed Loop Fuel Control
okay a code finally came up
Old Jan 31, 2007 | 09:06 PM
Jet-Jock's Avatar
Jet-Jock
While not nearly familiar with this engine and diagnostics compared to the C4, looking at the charts there are a series of tests that can be done to isolate the ECT sensor using the scan tool and a resistor. But for the most part and general analysis would be a ECT sensor failing to get up to speed quick enough thus keeping the PCM in open loop possibly causing the stall, cut out. The ECT is suppose to rise steadily from start on up to 90°F where it should become stable.
It very well could be an ECT sensor. But I'm not an expert or anything.
Old Jan 31, 2007 | 09:18 PM
dwarmenzerk
anyone have any ideas on its location.. i found another thread that said it could be dirty.. .. thanks guys!
To just stalled..
