not sure how to interpret the results...Is the SAE corrected the actual HP then
I'm wondering about this as well just purchased LG pro thought these were good for 30+ RWHP but it seemed like you only gained 20 RWHP from both intake and headers? Unless the SAE number is the actual HP?
I thought the "corrected" #s are supposed to reflect an equalization of conditions which will vary and which would otherwise affect the #s. If I am correct, then your 35 hp gain seems to me to be in the ball park.
They told me the corrected #'s were what I actually made. Extremes of temp, altitude, etc affect #'s and across properly set up dyno machines the corrected #'s are supposed to be the 'real' numbers. I know some people scoff at this but.....I think if it wasn't 40 deg and snowing (yes the garage door was open)...for example 80 and at a different altitude my uncorrected #'s would be much different. Hopefully some senior members with more experience can chime in and correct me if I'm wrong...
When was your baseline done? If it were done the same day then that should be lower. The conditions should effect the baseline also. Numbers aside how does the car feel?
Brian
"One important note is when you dyno below 50-55 degrees I don't feel you're getting good numbers. Most correction factors are linear & will actually undercorrect for these temps. My point is with air that is cooler than this you keep getting additional correction without the motor making much additional power, because of things like fuel atomization etc"
So if I am interpreting things correctly my numbers are 390/371? Anyone back me up on this.....I don't want to quote this if I am supposed to be using the uncorrected numbers.
one of the graphs...
Reason: added more
You guys are forgetting that I was in a snow filled 40 degree garage for the tune...my corrected baseline was 271 with headers and no tune. The numbers you are quoting are dyno results under totally different conditions.
SO it seems your 'corrected' baseline adjusted for warmer weather should be about 370-hp.
IN any event, the 20-hp gain from an intake seems pretty good.
#'s adjusted for 80-deg weather should read --> 350hp (stock), 370hp (headers), and 390hp (headers + intake & tune) ?
