do you have to pull the engine to replace the headers?
Old Feb 1, 2007 | 06:33 PM
hk940's Avatar
hk940
Default do you have to pull the engine to replace the headers?
stock C5.
i dread the thought of pulling the engine or paying someone to do it. i can do most of the work on the car myself but it will be hard (read imposable) for me to pull the engine alone. the mods i plan to do are a honker intake, full exhaust package and much later a big cam and i know i will have to pay someone to put in the cam and all it's parts. that is fine but right now i would like to replace the headers back to the tail pipe and do it myself.
thanks.
hk
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
No you dont!
Old Feb 1, 2007 | 06:34 PM
turboed's Avatar
turboed
not at all,maybe loosen the mount and rise it just a bit but that's it.
Old Feb 1, 2007 | 06:41 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Depending what brand you go with, the worst you will need to do is loosen the motor mounts. Even then the job is straight forward and fairly easy.
Old Feb 1, 2007 | 06:44 PM
Virtual Geezer's Avatar
Virtual Geezer
Hmmm,
EG and GBVette seem to think you do (need to remove engine).
Old Feb 1, 2007 | 06:56 PM
cadallante87's Avatar
cadallante87
I did my Dynatech SuperMaxx system with only 18" clearance. I only needed to loosen the starter and remove valve cover on pass side. Simple install. Good luck
Old Feb 1, 2007 | 06:58 PM
16Again's Avatar
16Again
Originally Posted by Virtual Geezer
Hmmm,
Old Feb 1, 2007 | 07:02 PM
FactoryRaceCar
Hmmm,
Old Feb 1, 2007 | 07:21 PM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
I did my Dynatech super maxx system myself on ramps didn't even have to touch the motor mounts. It only took about 6hrs without any help I had never done anything like that before so it must be pretty easy
Old Feb 1, 2007 | 07:50 PM
istsme98's Avatar
istsme98
Originally Posted by 16Again
Old Feb 1, 2007 | 07:53 PM
vettes4fun's Avatar
vettes4fun
no, 3 or 4 hours and your done.
Old Feb 1, 2007 | 08:08 PM
brandtdavis's Avatar
brandtdavis
NO with TPIS LTs, my buddy and I did mine. Starter, valve cover, and car kind of high off the ground and you can do it in a day with the right tools and patience.
Old Feb 1, 2007 | 08:23 PM
rgtkst's Avatar
rgtkst
Hmmm,
not true!!! dont you remember, they remove it for an oil change. it was the dremmell that was used for the header change
Old Feb 2, 2007 | 09:36 PM
LEANDRO's Avatar
LEANDRO
I just put my TPIS headers in last week, and all you have to do is remove valve covers(easy) and starter and alternator. As far as the mufflers you will have to get the back end of the car as far as you can off the ground. I have heard of people cutting the factory muffler pipe that goes over the axel but then the muffler are really no good if you wanted to reuse them later. Just take your time and you will be fine. This forum is one of the best for people helping out people. There is no doubt in my mind that if you run into any problems that there will be more people to help you out than you could imagine. Good luck, have fun, and don't worry just take your time and you will be fine. Plus you will enjoy your car more if you are the one who actully does most of the work. Look at these links they might be some help for you.
http://www.ls1howto.com/index.php?ar...n_instructions
Old Feb 2, 2007 | 09:52 PM
No, you don't have to pull the engine to install headers. Do a search and you should find some threads that describe the process for installing the headers.
Old Feb 2, 2007 | 09:58 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
And that will depend on the header you are installing.
Old Feb 2, 2007 | 10:08 PM
oldschoolvette's Avatar
oldschoolvette
To do you have to pull the engine to replace the headers?
Old Feb 2, 2007 | 11:49 PM
Cole's Avatar
Cole
There MAY be headers that don't fit, but they are unknown to me. All that I am aware of do not require moving the engine. I installed my own - a 17 curse job, but not impossible or all that difficult. Just a bit awkward and frustrating as you try to twist and turn unweildy metal.
Old Feb 3, 2007 | 09:33 AM
Vega$Vette's Avatar
Vega$Vette
This tells you exactly what you need to do.
http://www.ls1howto.com/index.php?article=29
Old Feb 3, 2007 | 01:01 PM
94legaleagle's Avatar
94legaleagle
That is a good header install article - I put on Dynatech's, and I followed the LS1howto as much, if not more, than I followed the Dynatech instructions.
