Need some input?
Old Feb 3, 2007 | 10:59 AM
tngerman1999's Avatar
tngerman1999
Default Need some input?
I have been wanting to put C6 Rims on my C5 but am getting some conflicting info. from people selling wheels! My question is can I put 19x10 rims on the back without a problem? If any of you all have pics of 19x10 wheels on back could you plz post?
Old Feb 3, 2007 | 09:12 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
There are MANY posts on this subject. Do a search on C6 wheels on a C5 and get comfortable as there will be alot of reading. It's more of a question of "offset" in the rears, no problem with the front.
Old Feb 3, 2007 | 09:27 PM
tngerman1999
Default wheels
rims im looking for r exactly like the ones you have. what size wheel do u have on rear?
thanks
Old Feb 4, 2007 | 12:07 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
19x10 wheels fit perfectly fine on a C5 - what doesn't fit properly is OEM C6 wheels on the rear of the C5. The offset is wrong. The stock OEM C6 wheels have a 79mm offset - while the stock OEM C5 wheels have a 63mm offset. That means that the C6 wheels and tires will rub on the inner fender of a C5. People here have mounted C6 wheels on a C5 put have had to use spacers to push the wheel further out My buddy has 3/8" spacers to place the wheels so that there are no clearance issues.
The problem with spacers is that they create the potential for shearing wheel studs etc.
Your option is to buy an aftermarket C6 wheel in C5 offset and you will accomplish the appearance without creating a potentially dangerous situation.
I borrowed this from a post last week - to me it very clearly explains the meaning of wheel terminology.
More positive offset means the wheel sits in closer in the wheel well. I hope this helps clear up the confusion.
Old Feb 4, 2007 | 12:51 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
I've got CCW 505A's 19x10 in front and 19x11 in the rear. You can't use a tire with a high profile (more than a 30) on the front or you will get some rubbing. Other than that, no problems. As blacksedan87 mentioned, make sure that you get the correct offset. There are many vendors who sell C6 style wheels with the C5 offset.
To Need some input?
