More performance - engine mods versus new gears
Old Feb 3, 2007 | 11:34 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Default More performance - engine mods versus new gears
I suspect this has been discussed before, but I failed to come up with the appropriate search keywords, so I'll pose this question.
My MN6 '01 coupe is primarily used for pleasure driving. It is basically stock, as I'm not inclined to be wanting to tinker with it all the time, or encounter the aggravation of mods gone wrong. If I wanted a bit more visceral performance though, say to the level of a C5 Z06, could this be achieved by getting new gears, like 3.90s, as opposed to engine mods? I am an easy drive over to Rodney at RPM, and would have him do the work....
Your thoughts are appreciated.
Old Feb 3, 2007 | 12:53 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
Absolutely. Going from 3.42s to 4.10s is an instant 20% increase in torque, in all gears, at all speeds. Torque is what pushes you back in the seat, not horsepower, so you will definitely feel the difference.
Old Feb 3, 2007 | 01:09 PM
wamara's Avatar
wamara
Dave,
Thanks for the reply.
Old Feb 3, 2007 | 01:23 PM
spdislife's Avatar
spdislife
Best bang for the buck if you want SOTP improvement
Old Feb 3, 2007 | 07:29 PM
wamara's Avatar
wamara
Any other thoughts?
Would there be much difference between 3.90s and 4.10s?
Old Feb 3, 2007 | 07:32 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
The 3.90 that Phil did on mine were the single best mod I've done so far.
Peace
Chip
__________________
..................Click for
Old Feb 3, 2007 | 10:05 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I say go for the gears and you will love them. If I had not wanted to have big HP numbers I would have went with the gear change, it does make a big difference
Old Feb 3, 2007 | 10:24 PM
spdislife's Avatar
spdislife
Any other thoughts?
Not as much as the diff between the 3.90s and 3.42s
Most guys will say go with the 4.10s
Personally I'm keep my 3.42s for now...down the road
Old Feb 3, 2007 | 10:30 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
If you're going to stay mostly stock under the hood I would go 4.10s. You'll still only be turning about 2100 rpm at 80 mph, so gas mileage won't suffer much. Might as well get the full bang for the bucks spent on the mod. Guys that go with 3.90s usually either have or plan on serious engine mods, and feel that 4.10s would be "too much" in first gear.
Old Feb 3, 2007 | 10:33 PM
Mike Mercury's Avatar
Mike Mercury
Absolutely. Going from 3.42s to 4.10s is an instant 20% increase in torque, in all gears, (at any RPM), at all speeds. Torque is what pushes you back in the seat, not horsepower, so you will definitely feel the difference.
couldn't agree more.
Old Feb 4, 2007 | 01:22 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Ditto. My plan for Winter,2008. When I spun wrenches in a local Harley Dealership the biggest bang for the buck was Andrews gears (including countershaft sprocket) over engine work hands down.
Old Feb 4, 2007 | 02:17 AM
Pizzano's Avatar
Pizzano
Went from 2:73's to DTE stage 2 3:73's, with Headesr and xpipe and a mild cam and heads, let me tell you, night and day, the gears will get you into the powerband instantly, no matter what set up you have, that is why people mistaken gears as a HP mod, it basically gets you to wear you can use the HP to its full potential.
Old Feb 4, 2007 | 11:58 AM
wamara's Avatar
wamara
Originally Posted by Pizzano
... let me tell you, night and day, the gears will get you into the powerband instantly, no matter what set up you have, that is why people mistaken gears as a HP mod, it basically gets you to wear you can use the HP to its full potential.
That's sort of what I was pondering. While I know this will be heresy for many here, sometimes I have to wonder just how much power do we need. I'm reminded of the old adage, "It's more fun to drive a slow car fast then a fast car slow." (And I know, it's the most fun of all to drive a fast car fast ). While I certainly wouldn't say no to having more power, in the abstract, I'm not sure that I fully take advantage of what I have now, and perhaps gears would change that....
Old Feb 4, 2007 | 12:01 PM
vettes4fun's Avatar
vettes4fun
Old Feb 4, 2007 | 04:50 PM
mwvettec5's Avatar
mwvettec5
What skill level and tools are involved in changing out a complete differential ???
I've been thinking about 4.10 gears and would like to purchase a complete diff. and install myself.
Any hints/tips ???
THANKS !!!
Old Feb 4, 2007 | 06:20 PM
Wake Champ's Avatar
Wake Champ
Any hints/tips ???
THANKS !!!
HIJACK!
Old Feb 4, 2007 | 08:52 PM
LEANDRO's Avatar
LEANDRO
Any hints/tips ???
THANKS !!!
I agree about a hyjack... but anyways heres a link about the diff change
http://www.cajundude.com/differential.htm
To More performance - engine mods versus new gears
Old Feb 4, 2007 | 09:23 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
My first perf mod was 4.10s. They were perfect, fantastic, I loved the
gears, still do... But had I known then I was going to do the engine mods
I've done I would have probably gone with 3.72s or 3.90s. But if your
certain your not going to mod your engine then go with 4.10s, you'll love'm!
Old Feb 4, 2007 | 09:33 PM
bowtiebubba's Avatar
bowtiebubba
I just went from 3.42 to 3.90, im still smiling. The only problem i see now is ,traction.
Old Feb 5, 2007 | 12:56 AM
Pizzano's Avatar
Pizzano
Any hints/tips ???
THANKS !!!
http://mikemercury.home.att.net/index.htm
Check Mikes site out he shows a step by step of his changeout
