Help wake up the engine!!
Old Feb 5, 2007 | 10:45 PM
dwarmenzerk's Avatar
dwarmenzerk
Default Help wake up the engine!!
hey guys Im looking to wake up my engine for my 99 a4 coupe 82k miles on it. It is a Daily Driver, looking to wake up the engine.
car has few things done to it. Z06 mufflers, no cats, x pipe.
What would be the best modifcation for me (suggestions are welcome!)
Im looking to spend right around a grand or so.
I was thinking about 3000 stall converter and having a set of 3.42 gears put into current diff. (Currently have 3.15 performance ratio) not sure if heavy duty output shaft is needed.
or
ls6 intake manifold and vararam intake. or is an ls2 intake manifold set up better?
and tune if needed..
thanks guys.
Old Feb 5, 2007 | 10:58 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Are you going to be doing the labor yourself? you won't get a stall and gears for anywhere near a 1000 bucks. Go for a set of long tubes, or maybe a cam, although after labor and tuning it'll be more than a grand.
Personally i'd just hold off and put a blower on it and be done with it. Great gas mileage, and reliability, and even better power!
Old Feb 5, 2007 | 11:00 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
$1000 won't buy you much, sorry to be the bearer of bad news.
Get the gears - best bang for the buck short of N2O
zo6chik's Avatar
zo6chik
with that budget you better do the install yourself. long tubes or a cam would be a good bang for the buck
Old Feb 5, 2007 | 11:15 PM
dwarmenzerk
planning on doing install myself, minus gears. I have access to lift and sister's boyfriend is a mechanic..
What is the cost of gears/stall generally run?
EG are you set up to do tunes yet?
Im thinking ls6/ls2 manifold and vararam would be best for me at the time.
question is which manifold would be best?
Old Feb 5, 2007 | 11:17 PM
Stangkiller
With your current list of mods you won't notice much if any of a difference. between either of those or stock.
Old Feb 5, 2007 | 11:19 PM
dwarmenzerk
recommendations other than FI stangkiller.. Gimme a real world number for best options. hot cam package worth the price for power or is something better with tune? With a cam wont i need to get headers as well?
money aside. without going nuts
Old Feb 5, 2007 | 11:26 PM
Stangkiller
No 'need' for headers, with cam only you will make more HP than the headers would. Steve at Ct proved that.
I think a rough estimate is about 800 to 1000 in parts, plus a 500 dollar tune or so. That's doing it all yourself.
There's a lot of great cams available. The list of parts isn't too bad.
The cam,
Springs
Retainers
Pushrods
Gasket set.
Chris
Old Feb 5, 2007 | 11:37 PM
Brad@RevXtremeAutoSports's Avatar
Originally Posted by Stangkiller
................... and even better power!
Hmmmm, I can attest to that
To Help wake up the engine!!
