Tips or suggestions needed!!
Old Feb 6, 2007 | 10:21 AM
TEC6's Avatar
TEC6
St. Jude Donor '10-'11
Default Tips or suggestions needed!!
I am going to be removing the coolant tank and the windshield fluid tanks to paint them. How do I go about draining these so I can remove them? I need some suggestions or tips for removing these without making a real mess. If you have any pics of this process, please share them.
Old Feb 6, 2007 | 11:20 AM
jovette's Avatar
jovette
Clamp the hose with a vice grips, then pull off the end of the hose away from the container, and install a bolt/screw that fits tight inside the end of the hose, remove the vice grips and you should be able to remove without a big mess.
Old Feb 6, 2007 | 11:30 AM
BrianWe's Avatar
BrianWe
This sounds like a good idea. I just removed the bolts and quickly pulled the hoses off and plugged them with my finger. Only a few ounces of coolent came out. It worked but not the most elegant method.
Old Feb 6, 2007 | 11:46 AM
TEC6's Avatar
TEC6
I thought about using the vise grips but wondering if the tanks should be drained first.... If so, what's the idea way of getting the fluids from the tanks?
To Tips or suggestions needed!!
