Nitrogen
Old Feb 7, 2007 | 10:40 PM
sprk33's Avatar
sprk33
2018 Grand Sport
Default Nitrogen
Just put nitrogen in the tires today....Is there any great advantages other than it cuts down on the fluctuation in tire pressure during hot summer days and the Winter cold freezing days? It was free with the purchase of my new tires and wheels.
Old Feb 7, 2007 | 10:53 PM
robert123's Avatar
robert123
most think its
Old Feb 7, 2007 | 10:59 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
As long as you got it for free you did good.
Old Feb 7, 2007 | 11:25 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Benefits = zero, other than the money that is spent to fill the tires with nitrogen
Old Feb 7, 2007 | 11:32 PM
dndrsn's Avatar
dndrsn
I can't see any difference by looking at your pics.
Old Feb 7, 2007 | 11:41 PM
thisMSGgood4me's Avatar
thisMSGgood4me
No such thing as free. You paid for it in the price of the new tires and wheels you bought. If you don't believe me, ask the store to put some of that "free" nitrogen in all the tires of your other vehicles and see what they say then.
Old Feb 7, 2007 | 11:46 PM
Blown 346's Avatar
Blown 346
[QUOTE=sprk33;1558863903]Just put nitrogen in the tires today....Is there any great advantages other than it cuts down on the fluctuation in tire pressure during hot summer days and the Winter cold freezing days? It was free with the purchase of my new tires and wheels.
The only thing that it si good for is what you said, you wont have tire pressure flucuation like you would with normal air. Otherwise I myself wont wast the money for it, I would rather check my tire pressure regularly.
Old Feb 7, 2007 | 11:51 PM
DwarfDump's Avatar
DwarfDump
Nitrogen filled tires won't have the water content that air filled tires do. Most aircraft use N2 in their tires for this reason. I've heard crazy stories of almost half a gallon of water held in a tire after being filled.
Old Feb 7, 2007 | 11:56 PM
Vega$Vette's Avatar
Vega$Vette
Mine are 78% nitrogen
Old Feb 7, 2007 | 11:57 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
ditto
Old Feb 8, 2007 | 12:04 AM
Illini82's Avatar
Illini82
St. Jude Donor '07
Most of the pressure fluctuation is due to water vapor, using something inline to dry compressed air will usually give identical results to pure nitrogen. I can't believe the dealers who are charging $40 for tire rotating and nitrogen fill....
Old Feb 8, 2007 | 04:53 AM
larrysb's Avatar
larrysb
I own a plane and use nitrogen under high pressure in the landing gear struts, so I keep a cylinder in the garage.
Just for grins, I filled two of my tires with air from a Walmart 12v air compressor/tire filler. The other two I purged three times and filled to pressure with pure nitrogen from my cylinder.
Net result?
I challenge anyone to identify which two tires are nitrogen and which two are plain old walmart air.
They behave exactly the same WRT to temperature and pressure. No difference whatsoever.
The reason that aircraft tires are filled with nitrogen are two fold:
1. Aircraft tires are filled to much higher pressures and present a safety hazzard if a brake catches fire. (they do sometimes). Nitrogen doesn't support combustion.
2. Water etnrained in aircraft tires can freeze at the far below 0 temperatures found at high altitude.
Since my plane doesn't pose a fire hazzard or fly at jet altitudes, the only reason I have for putting nitrogen in them is because it is more convenient than lugging a compressor around.
Old Feb 8, 2007 | 08:06 AM
ghoffman's Avatar
ghoffman
Cruise-In II Veteran
That is the reason I use it. In a race tire, the DRY nitrogen (dry air would be the same) supposedly has less thermal expansion but it is a very minor effect if at all. I need a 150-250 PSI source for my Penske shocks so I have a small N2 bottle. I put it on a cheap dolly with tie-downs so now I don't need a compressor in my trailer at the track. Since I use my cordless impact wrench all of the time, the compressor is unneeded. Heck, since the N2 bottle on wheels is so convienent, I use it for my lawn tractor tires and my wife's Accord.
Old Feb 8, 2007 | 09:03 AM
R Devil's Avatar
R Devil
Old Feb 8, 2007 | 09:15 AM
You described the benefit that it gives. Nice looking set of wheels BTW.
Old Feb 8, 2007 | 09:26 AM
Omega Man's Avatar
Omega Man
From: I speak the truth. Harsh but accurate. The Woodlands Texas
St. Jude Donor '09-'10
It also has to do with the tires expanding at high altitude(or so I have been told by the pilots).
To Nitrogen
