I'm concerned that my painting skills leave much to be desired, for those of you who have painted your calipers, how difficult is it to get a good paint job o your calipers....or should i fork out the extra cash to have them powdercoated?
i done my rotors with kylon spray paint , i dont know if the paint got hot and softing took place and the dirt got in the paint but they wouldn't come clean. but then i went and bought the caliber paint kit. and the paint seems much harder and i didnt use the the brush that was in the kit i got one from a craft store
I painted mine using Duplicolor's Caliper painting kit and using a hobbyist's air spray gun set. Coated the finished product with High Temp Clear Coat. Came out perfect. However, the paint can easily chip if you scrape the caliper while putting on/removing the wheel. I have to believe the powdercoating is more durable and more forgiving to bumps and scrapes than paint is. However, the advantadge of paint over powder coating (besides the price) is it's simple and easy to touch up a knick or scrape. Not a challenging job, but like everyone says, 90% of a good paint job is in the preparation. Great winter mod. Good luck.
Paint them by hand with the Caliper Paint kit. Just make sure they are clean before you paint them, use the brake spray cleaner you get with the kit. Actually, many guys use Rustoleum high temp paint and a small brush if you cannot find just the right color that you want. Preparation is the key When using the brush method, apply a coat and let dry, then apply another. It is well worth the time to get that special look!
I done mine about two-weeks ago... It was a breeze, I just blew out all the brake dust with the air compressor, then got a wire brush drill attachment and gave them a quick scuff...
Last thing to do was paint them, I ended up using the regular DupliColor Torch Red paint, it is not high temp... So far it is holding up well, but I'm not sure for long-term how well it'll hold up...
I'll have to get some pics up... An easy DIY job and costs maybe $6.00 You can't go wrong!!!
so i don't even need the "caliper paint"? i guess i'll be getting some duplicolor.
At your own risk, I've done calipers before with regular DupliColor paint (and like I said, I done my vette too)... Only time will tell how long they last though, but I'm confident...
As a side-note, get a can of duplicolor clearcoat... It gives them an unbelievable gloss "look" and makes them look so much better! I need to get pictures posted, maybe this afternoon...
~Chris
its very easy to do, just clean the whole area well, buy the color you want in a spray can, and paint them, i did a car of mine 4 or 5 years ago and the color is just starting to wear...dont bother doing the rotors b/c the caliper will just rub it all off. This is a good cheap appearance mod though!
I used some Folia Tec caliper paint on mine over 5 years ago and it is still looking very, very good. It is an epoxy based paint and dries very hard. As long as you get the calipers clean, the paint just brushes on and when it dries, you're all set.
Powdercoating is a good way to go too, but I would imagine that if you ever nick it and chip the powdercoat, it would be much harder to touch up. However, it does look good too. One disadvantage is that you will have to take the calipers off to do the powdercoating.
i did the calipers on my 89' a few years ago with the krylon ceramic paint and they still look good. but i cleaned the he(( out of them before painting ( eagle etching aluminum cleaner ). my question with powdercoating is, how does it affect the ability of the caliper to release heat built up during hard and constant braking?
One of the vendors here does a core swap, he sends you powdercoated C5 calipers and you send yours back when you swap them, pretty simple.
I hand painted mine with RustoLeum aluminum paint and after drying spread them with hi-temp clear. That was over two years ago and they still look good.
Getting ready to redo mine in BLACK this time. I have done it three times and it is very easy. I paint the entire thing and then take a sander and touch up to get the lettering back to the metal finish.
