Alternator Cleanup Advice Needed
Old Feb 8, 2007 | 08:58 PM
redrider's Avatar
redrider
Default Alternator Cleanup Advice Needed
New owner of a 2002 Vert. Everything stock under the hood and clean. Appears to have been well maintained by previous owner. Only eyesore is the alternater and bracket have a white oxidation like residue that I would like to spruce up and get to look like new. Any suggestions on what metal cleaners or polishes to use and technique appreciated.
Old Feb 8, 2007 | 11:13 PM
2klude's Avatar
2klude
Old Feb 9, 2007 | 01:49 AM
RIJVETTES's Avatar
RIJVETTES
I have the same complaint about the alternator on my 02. The finish looks crude enough to have been caste in a third world country. My C3 and C4 alternators were much smoother. It needs a good rub with steel wool- but thats not a good idea. I'm interested to hear some metal cleaning or polishing suggestions too.
Old Feb 9, 2007 | 06:59 AM
maxfli's5's Avatar
maxfli's5
i took a 4 inch grinder and a soft pad from home depot and some of the polish they sell with it and polished mine out . i didnt do any sanding i just start polishing . i even done the throttle intake and tensioner . you get very dirty doing it but the end results i think are worth it . i'll post some pics tonight
Old Feb 9, 2007 | 07:10 AM
pdd000's Avatar
pdd000
i just put a red one on, but ill be waiting to see sum pics of the polished bracket
Old Feb 9, 2007 | 08:15 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
What you are seeing is a common condition.
Here are a couple of solutions (vs spending time attempting to clean them up ):
Old Feb 9, 2007 | 01:28 PM
I'm not sure exactly how well it would work, but you might want to try a product called Never Dull. It is made for cleaning all types of metal and it may just remove the oxidation that your alternator and bracket has.
Old Feb 9, 2007 | 01:30 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I used some 000 steel wool and metal polish. Did it a year ago, still looks clean
To Alternator Cleanup Advice Needed
