Will this work????
Old Feb 9, 2007 | 06:24 PM
redjetty's Avatar
redjetty
Default Will this work????
I tried posting this in wheels, but nobody is home,, so will try here,, i have an 04 convertable that i want to put new wheels on with my exsisting tires, they only have 4800 miles on them, will the tire pressure monitor sensor work or not in an after market rim?? thanks, rj
Old Feb 9, 2007 | 06:57 PM
redjetty's Avatar
redjetty
come on,, someone help me out here
Old Feb 9, 2007 | 07:05 PM
Vassili's Avatar
Vassili
Mine,s a 98 and my mechanic used the same tires and sensors. No problems here.
Old Feb 9, 2007 | 07:10 PM
DAYCRZ's Avatar
DAYCRZ
Yes they will work, no problem on my CCW's
Old Feb 9, 2007 | 07:12 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Ditto here.
Old Feb 9, 2007 | 07:40 PM
oldschoolvette's Avatar
oldschoolvette
PlumberMike's Avatar
PlumberMike
They should. I kept my same tires and got new wheels and they work fine.
Old Feb 9, 2007 | 10:09 PM
Cart99's Avatar
Cart99
I had a small problem with air leakage, but a fatter o-ring solved the problem.
Old Feb 9, 2007 | 10:24 PM
KidShalene's Avatar
KidShalene
Just pulled mine from the stock wheels and installed in aftermarket's today....No problems what-so-ever, and still worked on start-up, no re-training necessary.
To Will this work????
