AN fittings?
Old Feb 10, 2007 | 09:03 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Default AN fittings?
How do you figure out what size is a AN fitting is.I know it has a number,But what does that number mean.I've been messing with cars & motorcycles for year's and never knew what the number's mean.Example, -03 AN or -08 AN or -12 AN...........Paul
Old Feb 10, 2007 | 09:09 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The number is expressed in 16ths.
So, a size 8 fitting = 8/16", which is 1/2".
4 is 1/4"
6 is 3/8"
16 is 1"
etc etc...
Old Feb 10, 2007 | 09:12 PM
Bubbletop409's Avatar
Bubbletop409
The number is the equivilent of 16th of an inch, ie 04 would be 4/16th or a 1/4" i.d., 08 would be 8/16th or 1/2" i.d. and so on. Be aware though that AN and JIC fittings have a different sealing taper angle, and should not be mixed.
Old Feb 10, 2007 | 09:15 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Oh shoot! That's pretty easy,Thank's.OK what's JIC fitting's? What's the AN stand for?..................Paul
Old Feb 10, 2007 | 09:17 PM
highdesert's Avatar
highdesert
From: I’m sittin’ at a bar on the inside. Waitin’ for my ride on the outside in Verdi, NV
St. Jude Donor '09-'10-'11
And also, hose size is the measurement of the inner diameter of the hose.
-2 hose has an I.D. of 1/8"
-3 hose has an I.D. of 3/16"
-4 hose has an I.D. of 1/4"
-5 hose has an I.D. of 5/16"
-6 hose has an I.D. of 3/8"
-8 hose has an I.D. of 1/2"
-10 hose has an I.D. of 5/8"
-12 hose has an I.D. of 3/4"
-16 hose has an I.D. of 1"
-20 hose has an I.D. of 1 1/4"
Old Feb 10, 2007 | 09:20 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Cool The reason I ask is I want to update trans lines going to my cooler.Thank's again................Paul
Old Feb 10, 2007 | 09:26 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
JIC and AN fittings both use a 37* flare, and same thread size, and ARE compatible.
JIC fittings are most common on high pressure hydraulic hose/tube fittings in the industrial world....where AN is mostly automotive/aircraft/military.
There are also 45* flare fittings which are old, but still common in the industrial world. These are NOT compatible with AN or JIC fittings. Flare angle and threads are different.
Old Feb 10, 2007 | 09:38 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
I was just looking through a Jeg's catolog and it said for a fitting I was looking at "They easily connect to standard 37* AN style adapter fitting's" No clue what that meant,But now I do.Learn something new every day.
Old Feb 10, 2007 | 09:46 PM
LoneStarFRC's Avatar
LoneStarFRC
JIC = Joint Industry Conference Roughly the industrial equivilent of AN
AN = Army Navy (though some sources say Air Force Navy) Basically a military/aerospace standard.
To AN fittings?
