Help installing new exhaust
Old Feb 11, 2007 | 09:56 AM
vet4me's Avatar
vet4me
Default Help installing new exhaust
Is there anyplace I can get instructions on installing a Z0 6 exhaust on my 2000 A4? Thanks for any help...
Old Feb 11, 2007 | 10:30 AM
Groucho's Avatar
Groucho
Default Well...
I can offer this,
You will need a lift...one that allows room to move around so you can wiggle the old out and the new in. Lifts that the tires drive up on are not goona work. You need the lift that lifts by the jacking points on the body.
Good luck and wear goggles.
Old Feb 11, 2007 | 10:31 AM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Here's are instructions on installing Borla Strikers. The process will be the same for most other cat-back set ups.
http://www.97vette.com/howto/mufflers/index.html
jrose7004's Avatar
jrose7004
I took mine to a local shop and paid them $60.00 to install my cat back.
Old Feb 11, 2007 | 10:49 AM
LeeJones's Avatar
LeeJones
From: I saw her today at the reception.....a glass of wine in her hand...
Old Feb 11, 2007 | 11:06 AM
Patches's Avatar
Patches
4-post lift works fine. I've done it and it's been done by many others. The car simply needs to be positioned on the lift so you can maneuver the exhaust as you take it off. A couple here have even backed the car up to a loding dock to swap their's. Otherwise it's a two-poster for the easiest swap or diy by jacking the rear at least 32" from the bottom of fascia to the ground (not recommended for the inexperienced). With an A4 you'll need to remove the passenger-side fuel tank shield.
You can see that it's easily done on a 4-poster.
Here's a couple of shots of a swapdone with jacks.
To Help installing new exhaust
