3D flames close up,, see inside
It looks very original and different, they did a good job on it.
This is assuming that you would use a machine to do the work. If you do it all by hand, no big deal.
However, if you use a machine, those raised edges would eventually wear down stripping the clear envoking clear coat damage. That was what my concern was.
Using a polish is like using 5000 grit sand paper. If you use a semi-aggressive polish too much, especially on the hood, your going to wear the clear away. Those raised edges will get hit harder than anything else.
Am I the only one that see it this way?
100%, IF this were a daily driver, but I have a feeling it's not, so polishing most likely won't be an issue. Very nice. Very original. Two
