Changing rotors advice
Old Feb 13, 2007 | 07:16 AM
VinnyT's Avatar
VinnyT
Default Changing rotors advice
I will be installing new rotors on the front of my 98 this weekend. Any tips on doing this? Any special tools?
Thanks all!
V.
Old Feb 13, 2007 | 09:52 AM
Vega$Vette's Avatar
Vega$Vette
1/2" breaker bar as sometimes the bolts to the caliper bracket need a lot of force to brake loose. I use the old pad on the piston side of the caliper and compress it with a 6" clamp. Then just use a little brake lube on the metal to metal contact point between the pads and the calipers.
Old Feb 13, 2007 | 12:07 PM
Last C5's Avatar
Last C5
Probably stating the obvious here, but if they are stock rotors and have been on for a while use some PB Blaster or other penetrating spray on the rears before you start hammering on them to get them off. It really helps.
Old Feb 13, 2007 | 12:15 PM
fixvet's Avatar
fixvet
There are ALOT of threads about doing this. Do a search on this forum and the C5 Tech forum for details.
Not very hard to do a brake job on a C5.
Have fun!!
Old Feb 13, 2007 | 01:16 PM
Vega$Vette's Avatar
Vega$Vette
He's doing the fronts.
To Changing rotors advice
