Lowering problems......
Old Feb 14, 2007 | 07:25 PM
Shaun Patrick's Avatar
Shaun Patrick
Default Lowering problems......
I lowered my vette a while back on stock bolts, and stupid me got in a hurry, and I didn't mark the bolts to know where I started out. Anyway, I lowered the front all the way to the bushings, and I did the rear bolts the same amount of turns. About a week later I measured on a level surface and noticed that my measurements are different on the left and right sides of the rear of the car, and the same goes for the front. How can I get the car Leveled out on the left and right sides of the front and back of the car? I hope this doesn't sound too confusing but I need to get this baby straightened out. Help me out if you can. Thanks in advance.
SPF
Old Feb 14, 2007 | 08:50 PM
dajael
Guest
Posts: n/a
SPF
Are you the original owner? Are you positive the car has not been lowered in the past and then possibly raised back up for re-sale? Did you check to see if the bushings had been cut or tampered with? Did you measure the height at all 4 corners prior to lowering and were they the same (respectivley)?
As far as the front goes... your best bet would be to remove the bolts, measure them and see if they are equal and if not then cut enough of the bushings to make them equal and then reinstall and count the exposed threads on each side.
For the rear, I would count the exposed threads on the bolts and make sure you have exactly the same number on both sides showing above the nut, you could also measure this distance but it is a bit harder.
Old Feb 14, 2007 | 08:55 PM
Dennis Wilson's Avatar
Dennis Wilson
If you have the fronts all the way down I would start with the rear, find the highest side and try backing down 1 turn at a time until its even with the other side You will have to drive it each time to settle it In my experience with mine [lowered all the way with cut bushings front & rear, ] It will change heights each time I park just slightly. it will vary maybe 1/4th inch at any corner . For a point of reference mine is 3 1/4th inches from ground behind front wheels & 3 1/2 inches in front of rear wheels. Hope this helps you a little.
Old Feb 15, 2007 | 12:58 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
SPF
If you're looking to level the car out front and rear, I would'nt even look at the # of threads onthe bolts. Basically, take out a tape measure and check the height at each corner, on the same spot on each side, this will be more accurate
p.s.-if you are changing ride height, most likely you will change alignment angles, so I'd suggest re-aligning her when you done!
Old Feb 15, 2007 | 01:50 AM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
w/ what all were saying, maybe drive it a bit and try again.
The ground my look level and not be.
Paul G.
Old Feb 15, 2007 | 11:34 AM
dbirdz06's Avatar
dbirdz06
Paul G.
Old Feb 16, 2007 | 04:13 PM
oldschoolvette's Avatar
oldschoolvette
Paul G.
good idea hope it works out
Old Feb 16, 2007 | 04:15 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Some good profile pix would really help here...
Old Feb 16, 2007 | 04:30 PM
BitViper's Avatar
BitViper
Originally Posted by dbirdz06
What if you measured from the middle of the wheel...thats would give you a relative measurment
Old Feb 16, 2007 | 04:54 PM
dbirdz06's Avatar
dbirdz06
Exaggerate the ground being unlevel. If your car was sitting on a 30 degree angle where the right side of the car was well below the left side, the load would transfer to the right. This would cause the fender to tire measurement or rocker panel to ground measurement to be much smaller on the right side vs. the left.
Yes, 30 degrees is a lot more than an almost undetectable amount on a garage floor or driveway, but I think it's enough to mislead you into thinking your car is level when it really is not.
Old Feb 16, 2007 | 08:39 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
To Lowering problems......
