aftermarket cd player install?
Old Feb 15, 2007 | 04:46 AM
2klude's Avatar
2klude
Default aftermarket cd player install?
I just bought a panasonic indash screen with built in dvd player. I have never installed a deck in a car before but i am going to attempt the install myself... how hard could it be.
Is there anything i should be aware of before the install. i remember awhile ago i was going to buy a cd player from a local audio shop and the installer told me i would need to buy a special harness since the car is a c5 corvette. I kinda of think he might have been BSing me... any truth to this?
Just wanted to know if there is anything i should know or buy before attemping the install.
thanks guys
Old Feb 15, 2007 | 05:29 AM
Gothikka's Avatar
Gothikka
you can either cut and splice wirest or buy the wiring harness. IMO...get the harness.
The hardest part is mounting the head unit. If you get the harness you can just plug it in.
Old Feb 15, 2007 | 07:03 AM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Kian, check out the Audio/Electronics section in the C5 community...lots of knowledgeable guys there who should be able to help you out
PS: Nice wheels
Old Feb 15, 2007 | 09:36 AM
BRKLYN's Avatar
BRKLYN
thanks guys
Save a lot of grief,Charlie Brown.Get the plug and play harness.Makes it simple and clean install.Not to mention you'll keep your sanity. : good luck
Old Feb 15, 2007 | 11:28 AM
hellotbone's Avatar
hellotbone
If you have the BOSE system them make sure and get the right box/module that lets your speakers play bass.
Old Feb 15, 2007 | 11:33 AM
boyblue97's Avatar
boyblue97
PS: Nice wheels
Old Feb 15, 2007 | 12:10 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
if your unit as a fold out screen (and is otherwise a 1 DIN unit) there shouldn't be too much of a problem. If you have a 2 DIN or larger screen....you're in for a world of fun
(see the C5 Audio FAQ sticky on the audio section)
Old Feb 15, 2007 | 03:26 PM
chris308's Avatar
chris308
U also may need to get a GM antenna adapter.
To aftermarket cd player install?
