Why is my grip so bad?
Old Feb 15, 2007 | 03:48 PM
Kale's Avatar
Kale
Default Why is my grip so bad?
04 w/magnetic suspension. Goodyear GS-d3 (fairly new)
I slide a lot in right turns on the road, kick in AH, etc. And the tires start to break around ~45 on onramps.
Compared directly to my Saab 92x w/Firestone Wide Ovals (205/55/16) it's kind of sad.
It starts to let go around 50-55mph on the same roads, and seems to have a lot more grip overall (as well as handling better.)
Should I just expect this suspension to handle poorly?
fwiw I took a coworker out to lunch (2002 mustang gt) and now he's wondering what all the fuss is about after I shrieked around a corner at low speed.
Tire pressure is good.
Old Feb 15, 2007 | 04:26 PM
DefenderC5's Avatar
DefenderC5
How new are the tires? http://www.tirerack.com/tires/tirete...e.jsp?techid=5
I have no handling problems with my base FE1 suspension and GY Runcraps.
Old Feb 15, 2007 | 04:27 PM
Kale's Avatar
Kale
maybe 3 months, about 1500 miles.
Old Feb 15, 2007 | 04:31 PM
o2z51's Avatar
o2z51
how many lbs of pressure are you running?? it should be around 32, if thats ok sound like your tires are old maybe dry rot??? check for cracking on the side wall and lastly could be the weather if you have summer only tires and its really cold the tires also wont grip
Old Feb 15, 2007 | 04:38 PM
Kale's Avatar
Kale
keep them around 32 cold, they were at 35 or so today after the ride.
outside temp around 68f
Old Feb 15, 2007 | 04:40 PM
jbauch357's Avatar
jbauch357
When was the last time you had your alignment checked? It may just be a matter of adjusting camber/caster/toe to be a little more agressive...
Old Feb 15, 2007 | 05:21 PM
Kale's Avatar
Kale
Aligned about 1000 miles ago
Old Feb 15, 2007 | 05:24 PM
o2z51's Avatar
o2z51
somethings not right may have it checked by a vette pro???
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Exactly what I was thinking. Bad alignment, caster, camber and you're not laying down all the rubber you think you are on those on ramps..
The GS-D3's are awesome tires. THEY are not to blame.
Old Feb 15, 2007 | 05:29 PM
jbauch357's Avatar
jbauch357
what size tires are you running?
was the alignment just toe, or did it include caster and camber?
do you have 500lbs worth of subwoofer in the rear?
is it just cornering traction that is bad or does straight line acceleration even prove bad traction?
Old Feb 15, 2007 | 05:33 PM
fdxpilot's Avatar
fdxpilot
You say it has the F55 Magnetic Ride. Are the stuffers still on the shocks? That seems to be a common problem with dealer prep. Makes the car ride and handle like crap.
Old Feb 15, 2007 | 05:35 PM
Oldvetter's Avatar
Oldvetter
32 psi is probably too high. You should have 30 psi cold maximum. In the winter, I go down to 26-28 psi cold. Lots of people run 28 psi cold.
But I agree, with your tires something is wrong.
You are not adding a lot of power on these curves are you? In cold temperatures, it doesn't take a lot to lose traction. These are summer tires !
You got cute with your city and state location, so I don't know what kind of winter temperatures you see?
Old Feb 15, 2007 | 05:51 PM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
All you do with higher pressure is wear out the center tread of your tires. 30psi...COLD. I check mine each month as the "mean" temperature changes.
Old Feb 15, 2007 | 05:56 PM
Kale's Avatar
Kale
I'll drop the pressure a bit, as said earlier it was 68 out. I usually dont hit the corners hard unless it's over 60. I'm Grandma when it's 50 and less.
I usually apply very little power, I'm not an overly aggressive driver.
Shocks are clear of the collars.
When I had it aligned (at a dealer) they said camber was "slightly off" and toe in was "way off." so I assume they adjusted camber, but I suppose I have no real way of telling. I'll take it somewhere for an alignment check.
It sticks a lot better now than it did with runflats, though.
Stock size tires for the coupe, nothing adding weight in the car yet. Though I have the Corsa titanium exhaust system, not that It matters.
The car is lowered, it sits level (no rake)
As far as straight line... its pretty easy to lose traction. Sometimes if I go WOT in 1st, the car feels like its skating sideways a little (even if i take off gently and ease into WOT)
Old Feb 15, 2007 | 05:58 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
I'm running the GS D3s Too. Base suspension, Zo6 Sway bars and Bilstein shocks. Drives likes she on rails.
Old Feb 15, 2007 | 06:11 PM
Jet-Jock's Avatar
Jet-Jock
You have something wrong, and some good ideas of things to check are listed.
I know I'm running Michelin Pilot A/S ZPs and being a runflat it still rides like it's on rails into a cornering or sharp turn. Nearly to the point of snap your head tight.
Oh I am completely stock except the tires.
Old Feb 15, 2007 | 06:27 PM
jbauch357's Avatar
jbauch357
Just cause they noticed the alignment was off doesn't mean they did anything about it - too many lazy shops out there. Most places that do quality honest work will have a record of what the specs were before and after the alignment - you may see if this documentation is still available.
How far did you drop the car? Go too far and you are reducing the effectiveness of the suspension and killing your handling capabilities...
To Why is my grip so bad?
Old Feb 15, 2007 | 06:32 PM
Kale's Avatar
Kale
Not much. .5 in the front, i think 1" in the back.
Old Feb 15, 2007 | 06:39 PM
jbauch357's Avatar
jbauch357
I would have to says first things first and make sure the alignment is dead on.
After that you may start looking at upgrading sway bars and shocks to help handling, or going with a wider wheel/tire package like a Z06 setup...
Don't quite know what else to tell ya?
Old Feb 15, 2007 | 06:41 PM
Kale's Avatar
Kale
yeah, I have swaybars because the amount of body roll this car has is silly. Not installed yet though. I probably wont upgrade it past there. I was just disappointed that my station wagon feels a lot more confident in the corners.
