noisy fuel pump
Old Feb 17, 2007 | 10:00 AM
rc69wc's Avatar
rc69wc
Default noisy fuel pump
every time i put a full tank of gas in my c5 the fuel pump makes a high pitch noise it only does it when i first start it up in the morning,anyone ever have this problem,and if you did was it a easy replacement or a pain in the *** like most gm vehichles
Old Feb 17, 2007 | 10:40 AM
Oldvetter's Avatar
Oldvetter
This is a puzzle. The early years C5s had a noisey fuel pump, but I think that was fixed in 1999 or 2000. My 1998 has a noisy fuel pump, it is worse when it is cold (early morning startup) and goes away when it warms up (or is warm outside).
BUT, yours is a 2003 C5, should not be noisy. Early year's pumps were just noisy, the noise did not mean that they were bad, but I would worry about yours ? It might be going bad. You could check fuel pressure, especially when it is making noise.
BTW, you have two fuel pumps and tanks. Usually the one behind the driver is bad/noisy. Replacing these can be a chore, you must drop exhaust pipes and go in through bottom.
Old Feb 17, 2007 | 01:28 PM
c5vette_dallas's Avatar
c5vette_dallas
JUST GO SHHHHHHHHHHHHH
Old Feb 17, 2007 | 01:54 PM
It's a PITA to replace.
Old Feb 17, 2007 | 02:10 PM
2blklt4's Avatar
2blklt4
i got same thing in my `98....i first thought it was a speaker going bad but...i guess is the pump
Old Feb 17, 2007 | 05:01 PM
rc69wc's Avatar
rc69wc
Default i will try that
if that dont work i just simply tell it to shut the hell up
Old Feb 17, 2007 | 05:44 PM
c5vette_dallas
wow...never thought of that....and if that dont work.... dun na na na hamma time
Old Feb 17, 2007 | 07:50 PM
whiplash 1's Avatar
whiplash 1
I have a 97 drivers side that whines all the time. I purchased a new back-up pump and sender unit and will drive it until it fails. I have been told the same thing that the pumps are noisy. Once I get going my Borla Quads drown the noise out.
Old Feb 17, 2007 | 08:59 PM
beav626's Avatar
beav626
I have an 01 and mine is staerting to whine... GMPP will be happy to take care of this one.
BTW my 2000 silverado did this too and I sold it with 120k on the clock and it never died...
To noisy fuel pump
