Engine cleaning – the safe way!
Thanks,
Clayton from Las Vegas
Not a good idea. Rubber hoses and plastic trim under the hood deserve better than that....
Do a search here for engine compartment cleaning and read up......
Good luck.....
I find the method of using Simple Green with a 50/50 mix of water does a great job.
It is designed to not dry out rubber due to the dust seals and other rubber parts of the brake system.
I have never had issues with brake cleaner and rubber and I spray down my rear race rotors after EVERY pass down the track.
It gets on quite a few rubber parts (tires included)
lol
lol
I warm the engine to fully operational temp. Leave it running throughout the process.
In the old days, I would just get out the Dawn dish soap & kind of squeeze some out all over the engine, then hit it with the water hose, scrub with a soft brush & rinse. I know it sounds barberic, but it worked. I just covered the distributor & carb with a plastic bag.
Today, I use some Simple Green or other cleaner like it. I give the engine a quick spritz with water, spray the Simple Green all over it at 100% strength, scrub what needs to be scrubbed with a rag or soft brush, then rinse with my power washer.
In both cases, days of old & present day, I run the engine after I'm done to evaporate as much water as possible. Now that I have compressed air, I dry the engine off with the air.
I cant understand why so many people think its taboo to wet an engine with water.....use a bit of common sense & avoid doing stupid things like holding the psi washer an inch away from the computer
, and you wont have a problem.
Simple Green is great stuff, but I only use it as necessary. Usually, my only problem is dust. My engine compartment tends to stay remarkably clean. I use a California Duster and apply rubber & vinyl protectant on a regular basis. Simple Green only as needed.
