[Z06] Front Spring Bushings
Old Feb 18, 2007 | 09:56 AM
freedomw's Avatar
freedomw
Default Front Spring Bushings
Hi everyone,
I have an 01 Z that the previous owner lowered dramatically.
Although it looks great, I drag on the ground everywhere I go.
It looks like the bushing for the front leaf spring was cut and I would like to replace the bushing with a new part. I have looked all over the internet and can't find a sounce for the part. Can anyone point me in the right direction.
Old Feb 19, 2007 | 02:46 PM
Mikey Z's Avatar
Mikey Z
I also have an 01 and wanted to change the bushings just because they look dried out ,so I started calling parts stores and all local dealer ships to find out that they are only sold as part of the front spring assembly for about $700. Good luck in your search
Old Feb 19, 2007 | 04:45 PM
hotwheels57's Avatar
hotwheels57
search is your friend.
If you use the search terms "bushings"(?) or similar terms, you'll find the name of after market source who sells the bolts/bushings separately. I can't think of the name off hand, but it's been mentioned several times for this issue.
Old Feb 20, 2007 | 06:21 AM
Z06Samuel's Avatar
Z06Samuel
I believe the company is called HARDBAR, I think the owner's name is George. Hope this helps.
Sam
Old Feb 20, 2007 | 03:10 PM
hotwheels57
That's it, but their website is hardbarusa.com
To Front Spring Bushings
