check engine light
Old Feb 18, 2007 | 01:07 PM
1Redctoo's Avatar
1Redctoo
Default check engine light
Yesterday the check engine light came on . I checked the codes and found these two
p0420 H C - twc system low efficiency bank 1 , I know the H is for History , what is the C for ? And more important what is the twc system?
second code
P1431 H - fuel level sensor 2 circuit performance , this one probably came up when we almost ran out of gas !
The car seems to run fine . Oh, by the way , its an '02 vert auto
Old Feb 18, 2007 | 01:57 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
The "C" means Current. That code was thrown very recently and with both H & C showing, the Current reading is not the first time the car has had reason the show that code.....
Do you have hi flow cats???
TWC = Three Way Catalyst
Old Feb 18, 2007 | 02:04 PM
1Redctoo's Avatar
1Redctoo
Thanks, I read that the 420 code is for the "three way cat system on the drivers side . I crawled around as best as I could and cant find any damage . Where are the sensors located ? And , should I clear the codes from the DIC ?
Old Feb 18, 2007 | 02:07 PM
Glennm27's Avatar
Glennm27
THat code can be thrown becasue the rear sensors are sending a reading that is not in close enough compliance with the front sensor..
If you have hi flow cats, or no rear sensors after a header install, I imagine these codes would show up without the rear sensors being "written out" using LS1 edit.
OR a bad 02 sensor
Old Feb 18, 2007 | 02:12 PM
1Redctoo's Avatar
1Redctoo
The car is totally stock so maybe its an O2 sensor . If I can locate it on the car I could probably replace it myself unless there is some computer stuff to do also .
Old Feb 18, 2007 | 02:38 PM
Glennm27's Avatar
Glennm27
The rear sensors are easy to find. They are on the "H" pipe after the cats. They would be about the middle of the car.
Old Feb 18, 2007 | 08:33 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
if the car is totally stock . i would look at a Cat issue as well , not just sensors . if the cat is gone bad , then the values of the rear sensors would be close enough to the front ones that it would throw a code .
Been there with my LS1 Trans Am , replaced the Cats and the issue was gone .
Old Mar 22, 2007 | 08:56 PM
cbrf4i1's Avatar
cbrf4i1
if you are getting that code your o2 is fine, it is your cat is done (since your car is stock) replace the cats or get it edit out or o2 sims which is the cheapest way. good luck.
To check engine light
