Door panel tool?
Old Feb 18, 2007 | 02:06 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Door panel tool?
What is the name of the fork like tool that allows you to get the door panel off.
Old Feb 18, 2007 | 02:19 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i think you are lookin for one of these http://www.cardomain.com/item/SOU87810
napa might have em
I always just pull like a **** and the panel pops off
Old Feb 18, 2007 | 02:41 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Here's a link from 'Vette Essentials' that might help.
http://www.vetteessentials.com/instr...or_handle.html
Old Feb 18, 2007 | 02:42 PM
brandtdavis's Avatar
brandtdavis
the putty knife with an old sock tool?
Old Feb 18, 2007 | 03:00 PM
screw991le's Avatar
screw991le
Thanks for the links, it guess it is easier than I figured.
Old Feb 18, 2007 | 04:29 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
HI screw991le -
I use a plastic pie-server/fork thingy - it looks like a plastic knife with a round nose -
All you need is a tool to pry with that won't cut or mar the panel -
Once you get one or two of the clips popped, then you can ust use your hand to get between the door and the beauty panel and pop off the rest.
best regards -
mqqn
Old Feb 18, 2007 | 04:35 PM
pentavolvo's Avatar
pentavolvo
ive never used the tool on the vette i just used the how posted above my first time, be prepared to pull effin hard if the panels have never been off before. when it finally comes loose you will think stuff is brakin its loud when the pins release the first time.
Old Feb 18, 2007 | 04:36 PM
That probably works too.
To Door panel tool?
