"leather" pulling away from backing on door panel
Old Feb 19, 2007 | 07:58 PM
ericdwong's Avatar
ericdwong
[QUOTE=Oldvetter;1559036001]
Originally Posted by BrianWe
I had the same problem with my 2004. It developed after the warranty expired though. I solved it with a set of leather armrests from Vette Essentials. An upgrade I highly recommend
This is what I did also.
WOW that iI likee that color combination, the center lid looks sharp!
Old Feb 19, 2007 | 11:06 PM
stepuptata's Avatar
stepuptata
thanks for the tips, my wife is a nurse. I'll have her get the needle. Thanks
Old Feb 20, 2007 | 01:14 AM
Try the needle and glue routine - that does sound promising.
Old Feb 20, 2007 | 05:05 AM
Choreo's Avatar
Choreo
Trying to figure out how the glue will activate in a closed space like that - seems like it would just stay in liquid form - like in the tube? Guess not?
Old Feb 20, 2007 | 10:44 AM
bomax's Avatar
bomax
I would like to give this a try but have no worldly idea where to get a needle from!
Old Feb 20, 2007 | 11:38 AM
BrianWe's Avatar
BrianWe
[QUOTE=hattitude;1559036334]
Originally Posted by Oldvetter
I have a question about this solution?
If the vinyl is "pulled away" from the backing, and you attach a vette essentials arm rest, which just glues on to the vinyl, won't the arm rest be loose....?
The armrests go on with a strip of double sided tape which was located in the center of the armrests. I suppose if you have a really bad problem, then this won't work. If you have a spot where you can use the tape, the armrests will help push down the loose vinyl so it really is not noticeable with a casual glance at the door.
Old Feb 20, 2007 | 11:53 AM
BATM4N's Avatar
BATM4N
By the way it isn't leather. Its vinyl.
Bill
Come on Bill get with the times It's Pleather....half plastic, half leather
