shifter help
Old Feb 19, 2007 | 12:47 PM
stanlee's Avatar
stanlee
Default shifter help
I am considering installing a short shifter on my 99 six speed. Which brand would you reccomend and is this a good idea? all help would be appreciated.
Old Feb 19, 2007 | 01:08 PM
NOS500's Avatar
NOS500
I installed a Hurst and Love it, nice short throws, with very precise shifting, a little notchy though. Many people have installed the c6Z shifter and they like it a lot. You should probably perform a search, this topic has been gone over a lot. Good Luck!
Old Feb 19, 2007 | 01:45 PM
dajael
Guest
Posts: n/a
I installed the C6 short throw in my '03 (before the C6Z came out) and I love it. Don't know if there is any difference between mine and the "Z" but it looks and feels great.
Old Feb 19, 2007 | 03:26 PM
slvr bulit's Avatar
slvr bulit
I installed the ripper from B&M and put on a delrin handle while I was at it. Love this set up. Easy to do also.
Old Feb 19, 2007 | 04:49 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
I got a Hurst and love it after I got the shifter **** I liked. Here is a great how-to-install.It is for a Hurst,but all others install the same way.
http://temp.corvetteforum.net/c5/pat...rInstall.shtml
Old Feb 19, 2007 | 05:06 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
Check your PM dude.
Old Feb 19, 2007 | 05:46 PM
TTK98's Avatar
TTK98
Installed a B&M ripper shifter. Works perfect! Just do a search
for how to install. Lots of good info here.
Old Feb 19, 2007 | 05:50 PM
shakainc's Avatar
shakainc
I have the C6Z shifter also and love the way it feels. It's easy too.
Old Feb 19, 2007 | 05:59 PM
stanlee's Avatar
stanlee
Default shifter install
sounds like the hurst or the c6 but someone said check my pm? Sorry I'm slow, but what does that mean?
Old Feb 19, 2007 | 06:06 PM
JUSTAKAR's Avatar
JUSTAKAR
You have a (PM) Private Message look at your name top right and go look at your messages ..
Ian
Old Feb 19, 2007 | 06:29 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
I run the Hurst. Short exact shifts and you won't miss gears.
Old Feb 19, 2007 | 06:31 PM
photoguy's Avatar
photoguy
Old Feb 19, 2007 | 06:56 PM
stanlee's Avatar
stanlee
Originally Posted by Nasty98
Check your PM dude.
Thanks now I know what a PM means thanks to justakar.
Old Feb 19, 2007 | 06:59 PM
stanlee's Avatar
stanlee
Check your PM dude.
Thanks to all replys.
Old Feb 19, 2007 | 10:41 PM
kevin40zx's Avatar
kevin40zx
I have the Hurst and like it a lot. But FYI, if you have not already heard, the Hurst has a tendency to rattle. Do a search "hurst rattle". Lots of info.
Old Feb 19, 2007 | 11:46 PM
BitViper's Avatar
BitViper
Im looking at shifters..and figure their all about the same..except....
Which one has the shortest stick...not throw..but stick.the stock stick is HUGE!
Old Feb 19, 2007 | 11:50 PM
ALLEGRO's Avatar
ALLEGRO
I got paranoid about the postings of noise and notchy-ness so I just cut an inch off of the OEM unit and buttoned her back up. I like the feel and shorter throws.
Old Feb 20, 2007 | 12:07 AM
hotwheels57's Avatar
hotwheels57
I shortened the oem shifter on my '04 Z16 by 3/4", then deleted the jamb nut that came with the HURST six speed ****. It isn't sloppy as others have complained and it looks better than the oem leather ****.
To shifter help
