Alternator Pully
Old Feb 19, 2007 | 04:08 PM
98blackonblack's Avatar
98blackonblack
Default Alternator Pully
I read a while back about there being a new pully design for the alternators on the vettes...i have a 98 and when at idle turning or backing out of a parking spot and turning the wheel it shakes the car and sounds like its going to die, sometimes it makes the belt squeal?
IS the alternator pully what causes this, and what is the fix?
Old Feb 19, 2007 | 04:12 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Sounds more like you have an issue with the power steering system.
Why would the alternator do anything different when the car is turning?
Old Feb 19, 2007 | 04:15 PM
98blackonblack
this is what im talking about
http://corvetteactioncenter.com/kb/q....php?qstId=260
Old Feb 19, 2007 | 04:23 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Do you have an A4?
Does you RPM's drop below 600 when turning the steering wheel to the lock position?
Or is your problem that when turning the steering wheel to less than the stops it 'shakes"?
It is possible that the steering unit is at fault if the answer to the last question is yes.
Old Feb 19, 2007 | 04:28 PM
Mike Mercury's Avatar
Mike Mercury
Correction: A new Generator with Decoupler Pulley and reduced damping Accessory Drive Tensioner was implemented for all Corvettes with automatic transmissions at 2001 SOP (Start Of Production). The generator with decoupler pulley is used only on Corvettes equipped with an automatic transmission. The reduced damping accessory drive tensioner is used on all 2001 Corvettes.
More likely the reduced damping Accessory Drive Tensioner than the alt pulley.
To Alternator Pully
