could someone post up a wiring schematic for the starter? we swapped motors and i believe our wiring is incorrect as we are experiencing the following problems:
• fuel pump will not 'arm'-hence zero fuel at rails (car turns over fine)
• HPTuners cannot connect to the PCM
• when key is in 'off' position, the seatbelt light is lit dimly and the car 'dings' like it would if the key was in run position
my guess is we have a ground wire on the hot side of the starter.
